71 340 choke ? #497808
10/15/09 11:11 AM
10/15/09 11:11 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
What is the correct part # for the choke? I've got a # BT-245 with a big 45 and the rod has a #527. the choke should be closed but its at the end of its travel and wide open, i do have a 1/4" inch spacer with two thin gaskets that i think were stock. Thanks
Re: 71 340 choke ? [Re: ademon] #497809
10/15/09 11:29 AM
10/15/09 11:29 AM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
The original Chrysler choke # for a '71 & '72 340 intake was: 3512875
and the Carter part # was: 170-148
The Carter # you have was originally for a '72 400 big block but is inter-changeable with the 340 #.
The Chrysler part # for '71 & '72 intakes is NS-1, meaning the choke is no longer avail.
Your carb to intake gasket does not require an additional thin upper and lower gasket; the original was made from Aluminum and was slightly thinner and used an upper and lower thin gaskets.
You will have to repair yours or find a good used or NOS choke, David.
Re: 71 340 choke ? [Re: DEMONSIZZLER] #497810
10/15/09 11:35 AM
10/15/09 11:35 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Ok thanks, the choke itself looks new, i'm guessing i need a longer rod from the choke to the linkage to make this one work.
Re: 71 340 choke ? [Re: ademon] #497811
10/15/09 10:36 PM
10/15/09 10:36 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Looks like this one:
Re: 71 340 choke ? [Re: ademon] #497812
11/01/09 12:06 AM
11/01/09 12:06 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Somebody has them on Ebay all of the time.
Re: 71 340 choke ? [Re: ademon] #497813
11/01/09 12:14 AM
11/01/09 12:14 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
FWIW If you don't want to spend the money on a new choke and have an intact used original I will restore them(dissasemble, replate, etc.) for no additional charge with any carburetor restoration I do, I'll also replate any supplied carb or intake manifold related parts (linkage, brackets) etc. at no additional charge.
Before:
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497814
11/01/09 12:14 AM
11/01/09 12:14 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After, same parts
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497815
11/01/09 08:53 AM
11/01/09 08:53 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Scott,after looking at both pictures,how did you get every part in the "exact" same location before and after in each picture?
Re: 71 340 choke ? [Re: I go fast] #497816
11/01/09 11:35 AM
11/01/09 11:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey, I couldn't help myself, have a marketing background, what else would you expect?
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497817
11/01/09 02:12 PM
11/01/09 02:12 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
"marketing background" or in this case...OCD
Scott are you plating this stuff yourself or is Vic doing it?
Re: 71 340 choke ? [Re: chrisf] #497818
11/01/09 02:56 PM
11/01/09 02:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Chris, yes I have OCD, oh well, at least you'll know that I did my best getting the details right on your stuff
*Vic and I are friends but we do not trade any work
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497819
11/01/09 04:45 PM
11/01/09 04:45 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
The rod with the swivel bracket on it is a little closer to the 2nd rod from the right, on the 2nd picture. You better correct that and retake it.
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497820
11/01/09 05:41 PM
11/01/09 05:41 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Obviously what Scott's done is just re-touched the photo using a photo shop program....That's how he does his carb restos too....He just sends you before and after shots...nudge nudge wink wink...
CHECK OUT MY NEW WEB SITE !
Re: 71 340 choke ? [Re: anlauto] #497821
11/01/09 05:45 PM
11/01/09 05:45 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
whats that little whatchamacallit on the part that goes on the throttle bracket with the black on it, it looks like a threaded part,is it a 70 or 72 thing? my 71 does not have that.
Re: 71 340 choke ? [Re: chrisf] #497822
11/01/09 07:06 PM
11/01/09 07:06 PM
anlauto Offline
anlauto  Offline
That's the threaded end that screws on the rod pictured on the far right
Re: 71 340 choke ? [Re: ademon] #497823
11/01/09 07:07 PM
11/01/09 07:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That carb and kickdown linkage is off of a 1969 340 A-body, it goes with the AVS carb shown below (ignore the BB intake).
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497824
11/01/09 07:52 PM
11/01/09 07:52 PM
Belleville Il
Dingmaster Offline
Dingmaster  Offline
Belleville Il
Wow,
I can't wait for that thing to show up! It looks too nice to run gas through it.
Re: 71 340 choke ? [Re: Dingmaster] #497825
11/01/09 08:27 PM
11/01/09 08:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's your tracking number Tim, Fed Ex Ground #371419310008081.
*(I reccomend Dixie Restorations for your Alternator)
Re: 71 340 choke ? [Re: ScottSmith_Harms] #497826
11/01/09 09:12 PM
11/01/09 09:12 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Nice AVS, is that a 68 avs? i have a 68 avs #4426 4- speed carb that has the single screw, and a 69 340 avs with the two screw idle adjusters. I like the avs's nice carb when set up right.
Re: 71 340 choke ? [Re: ademon] #497827
11/01/09 09:53 PM
11/01/09 09:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, it's a 69 (automatic). F8 date code makes it a June 1968 production date for an early build 69 model 340 car.
Avs's are good carbs, easy to adjust and work on, not typically the best for maximum HP but they'll give you a great all around drivability with respectable power and are generally trouble free once set up properly.
