72 Demon radiator #497354
10/14/09 08:02 PM
10/14/09 08:02 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
What are my options for bolt in V8 radiators WITHOUT having to cut and weld (at least the weld part) this or that? I'm assuming pretty limited but crossing my fingers anyways.
Mine has a hole in it and I figured if the price is right an aluminum radiator would look pretty cool. Otherwise I'll just order another stock unit.
Re: 72 Demon radiator [Re: chache876] #497355
10/14/09 09:28 PM
10/14/09 09:28 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I ordered the heaviest stock radiator that I could from Carquest. I think it was for a 340 w/ air. It keeps my 340 nice and cool. I run a pusher electric fan and no other fan. My fan clutch went bad and I had the electric with all the wiring and relay so I used it. I do not have a lot of stop and go traffic here so it works well for me.
Re: 72 Demon radiator [Re: Posest] #497356
10/14/09 09:33 PM
10/14/09 09:33 PM
colorado
chargermop Offline
chargermop  Offline
colorado
heres what i am going to use
http://www.alumorad.com/dodge.html
Re: 72 Demon radiator [Re: chargermop] #497357
10/14/09 09:40 PM
10/14/09 09:40 PM
Costa Mesa, CA
Costa Mesa, CA
Those all look like B body radiators, what are you putting it in?
Re: 72 Demon radiator [Re: chache876] #497358
10/14/09 09:59 PM
10/14/09 09:59 PM
colorado
chargermop Offline
chargermop  Offline
colorado
71 dart
Re: 72 Demon radiator [Re: chargermop] #497359
10/14/09 10:13 PM
10/14/09 10:13 PM
Costa Mesa, CA
Costa Mesa, CA
which model do you plan to use? Its going to bolt right up to your rad support?
Re: 72 Demon radiator [Re: chache876] #497360
10/14/09 10:19 PM
10/14/09 10:19 PM
colorado
chargermop Offline
chargermop  Offline
colorado
should drop in but I dont have one yet...
Re: 72 Demon radiator [Re: chargermop] #497361
10/14/09 10:28 PM
10/14/09 10:28 PM
Costa Mesa, CA
Costa Mesa, CA
Well we must have different radiator supports. My stock radiator has a 22" core and theres no way a 26" will fit without modifying it.
Re: 72 Demon radiator [Re: chache876] #497362
10/15/09 02:24 AM
10/15/09 02:24 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a 26" unit from a big Fury in my 71 Demon and all I did was align it and drill new mounting holes,never cut the core opening and it cools my big block engines just fine.
Nautilus Racing-
Re: 72 Demon radiator [Re: Chris2581] #497363
10/15/09 02:38 AM
10/15/09 02:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i have a 26 inch aluminum in 71 dart...did the same as above.
Tony
70 AARCuda Vitamin C
Re: 72 Demon radiator [Re: 70AARcuda] #497364
10/15/09 04:06 PM
10/15/09 04:06 PM
Costa Mesa, CA
Costa Mesa, CA
guess I was wrong, thanks!
