Q A1 SHOCKS
#497226
10/14/09 06:03 PM
10/14/09 06:03 PM
Posts: 273 Edmonton alberta Canada
mr. 63plymouth
Just wondering if anyone else had this problem, have a 68 barracuda with a small block pump gas naturally aspirated true street car with calvert mono leaf springs, caltracs with qa1 single adjustible shocks on a 10" tire.Car has a bad hop at about the 330mark, wondering if double adjustible shocks would actually get rid of the hop or not? Had the car in mission b.c canada last weekend and ran its best ever, 9.52@142.82mph with a 1.393 sixty foot. Thanx
Re: Q A1 SHOCKS
[Re: mr. 63plymouth]
#497227
10/14/09 06:11 PM
10/14/09 06:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just wondering if anyone else had this problem, have a 68 barracuda with a small block pump gas naturally aspirated true street car with calvert mono leaf springs, caltracs with qa1 single adjustible shocks on a 10" tire.Car has a bad hop at about the 330mark, wondering if double adjustible shocks would actually get rid of the hop or not? Had the car in mission b.c canada last weekend and ran its best ever, [Email]9.52@142.82mph[/Email] with a 1.393 sixty foot. Thanx
Have you tried different settings on them to see if it changes.... are your tires round and balanced
Re: Q A1 SHOCKS
#497229
10/14/09 06:35 PM
10/14/09 06:35 PM
MR_P_BODY
Yeh i have tried different setting from softer to the hardest.Balancing the tires I think is a bit of a grey area, because I thought that when you leave the line the tire is so wrinkled that it wouldnt matter on balancing, because if its balanced it forsure isnt when leaving the line.But maybe it could be part of the problem?
I know balance sure helps down track(at least it does on my car). Sure balance doesnt matter at the line, your not turning them fast enough to see it... By the way I use the QA-1 singles but havent seen your issues
Re: Q A1 SHOCKS
#497230
10/14/09 11:13 PM
10/14/09 11:13 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Is this hop occurng at the shift into second gear? or in the middle of second gear? I had a set of tires that would shake at around 70 MPH and again at 117 to 121 MPH in the quarter I would get the tires balance and take it back out to see if it(hop) is still there
