A518 transmission no reverse bad servo? 92 ram #497052
10/14/09 03:57 PM
10/14/09 03:57 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Just pulled the pan off the truck to investigate the no reverse problem. Found the reverse servo was broken and the lip seal was pushed down.. See pic. Seems to me that might be my problem. Truck is a 92 W150 and it lost reverse just all of a sudden. All forward gears seem to be fine. What do you guys think?
Re: A518 transmission no reverse bad servo? 92 ram [Re: ejtmopar] #497053
10/14/09 04:00 PM
10/14/09 04:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's your problem and not all that unusual.
Re: A518 transmission no reverse bad servo? 92 ram [Re: ejtmopar] #497054
10/14/09 04:06 PM
10/14/09 04:06 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Where can i get a replacement? Do they make an updated version so that might not happen again? Here is a better shot of the servo.
Re: A518 transmission no reverse bad servo? 92 ram [Re: ejtmopar] #497055
10/14/09 04:15 PM
10/14/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check the transmission/differential section of the swap meet forum for a billet piston, spring and retainer.
Re: A518 transmission no reverse bad servo? 92 ram [Re: John_Kunkel] #497056
10/14/09 04:22 PM
10/14/09 04:22 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Thanks for the tip!
Re: A518 transmission no reverse bad servo? 92 ram [Re: ejtmopar] #497057
10/14/09 04:26 PM
10/14/09 04:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can check local transmission shops too. I'm in the middle of building my 518. All of my parts came from Transtar.
- Stu Harmon
Re: A518 transmission no reverse bad servo? 92 ram [Re: feets] #497058
10/14/09 04:40 PM
10/14/09 04:40 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
sonnax makes upgraded replacement parts...although they are nothing like the billet ones...but nice to see alternatives to the stock parts
http://www.transmissionpartsusa.com/A518_A618_46RH_46RE_47RE_transmission_parts_s/61.htm
Tony
70 AARCuda Vitamin C
Re: A518 transmission no reverse bad servo? 92 ram [Re: 70AARcuda] #497059
10/25/09 06:59 PM
10/25/09 06:59 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Got it back together today. Everything went in way better than expected! And best of all Ive got reverse! thanks for the help!
