what do you think this will run?? any similar combos? #496544
10/13/09 07:25 PM
10/13/09 07:25 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Mt sons car is coming together,
we have a stock 1998 5.9 magnum engine.
only mods are Edlebrock intake, 650 Double pumper, 1 3/4 headers. STock 904, maybe a 11" convert? We also have an explorer 8.8 with 4.10 posi,He will be running 295 drag radials and we will have caltracs good shocks etc, Shooting for a car weight with driver of 3100-3000 hoping to get the car in the 12's and run an 11.50 index with a lil plate nitrous system
i know a friends dakota pickup with the same engine (factory fuel inj) ran 14.30's bone stock and in the 13's at a whopping 3900lbs...
....BAD A$$ STREET CAR.....
Re: what do you think this will run?? any similar combos? [Re: n20mstr] #496545
10/13/09 08:05 PM
10/13/09 08:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
Should run pretty good for a little street car. What camshaft is in it?
The only recommendation I would make is more converter.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: what do you think this will run?? any similar combos? [Re: Triple Threat] #496546
10/13/09 10:07 PM
10/13/09 10:07 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
cam is stock, motor is untouched, all we are doing is putting an intake and headers on it, 50,000 mile engine
Re: what do you think this will run?? any similar combos? [Re: n20mstr] #496547
10/14/09 10:37 AM
10/14/09 10:37 AM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
When I first put my dakota together it was very close to what you have and it ran 13.70s at 3465 lbs with me in it. It was stock except for a pro products airgap intake and 650 D/P. I have a 727 with a PTC 9.5 converter and thats the only difference I see between the two. I put some R/T 2.02 heads with some pocket porting done and a .230/.234 @ .50 .488/.513 lift cam in it and it picked it up to 12.50s a with a 125 shot it runs right on 11.50s
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
