Re: Spot weld cutters - any recomendations?
[Re: Birdturd]
#496497
10/14/09 01:05 AM
10/14/09 01:05 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Blair Rotabroach is a nice set up. Replacement cutters go for $8-$9 each, 5/16" and 3/8", 3 teeth. Buy extra locating pins too. Cut like a lathe but are brittle. I would get upwards of 1000 spots cut before it got dull (if I didnt break it first ) Been using the spotweld cutters from Harbor Freight lately. $3.99-$4.99 (depending on sale)Two sided cutter bit, also an "annular" (ring) cutter like the Blair. 8 teeth, not as brittle, will continue to work with a broken tooth or two. Maybe 200 cuts per side of cutter so upwards of 400 per unit. Dont overheat either one or it wont last long. I use bacon fat for cutting lube
[Re: nomore65BelvJim]
#496499
10/14/09 11:20 AM
10/14/09 11:20 AM
Posts: 821 NW Ohio
6pkaar
NW Ohio
Me too, They aren't as brittle.
[Re: 6pkaar]
#496500
10/14/09 12:08 PM
10/14/09 12:08 PM
Posts: 543 Indiana, Just Off I-70
BradD
It is best to use a low RPM, high torque drill to not dull the bit or overheat it. I use a Snap On 1/2 inch air drill that turns 800 RPM. My Blair bits last a long time. I also have used many Wurth 8mm bits that worked well. Brad Dorn Autocraft
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
#496507
10/16/09 10:38 AM
10/16/09 10:38 AM
Posts: 1,047 Arizona
68CoronetRT
Arizona
Blair Rotabroach is a nice set up. Replacement cutters go for $8-$9 each, 5/16" and 3/8", 3 teeth. Buy extra locating pins too. Cut like a lathe but are brittle. I would get upwards of 1000 spots cut before it got dull (if I didnt break it first ) . . .
I found that if I started the cutting process at a slow rpm that the cutters wouldn't break so easily. The cutters are brittle and the spot welds have high points on them so by going slower until you have good full contact on the weld (a complete circle being cut) then increasing the speed the cutters will last a long time.
