Pinion angle shim size question #496367
10/13/09 06:15 PM
10/13/09 06:15 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
I have a question on a common subject.
I have checked my pinion angle and I think I am at zero degrees.I am checking the driveshaft and the yoke while the car is on the ground. I get a negetive 2* or just in between 2* and 3* on the gauge. I get the same reading on the driveshaft and the yoke, they both read about 2.5* and it is both on the same side of zero. . they do look very much to be in line together. am I correct in that would be a zero? I have a 4* shim in the car now. I have super stock springs and they are in the upper mount holes.
how much more shim do I need?
I think I can get an 8* shim, or would a six* shim work. I am not sure of the geometry of the shims in relation to how much it moves the yoke.
I want to remove the 4* and only use one shim.
I hope I have explained myself well enough and thanks for the help
Re: Pinion angle shim size question [Re: Joshs68] #496368
10/13/09 06:24 PM
10/13/09 06:24 PM
calif
cupcake Offline
cupcake  Offline
calif
8* shim thats bout the size of a 2x4
Re: Pinion angle shim size question [Re: Joshs68] #496369
10/13/09 06:26 PM
10/13/09 06:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Oh...pinion angle question...never fear they will be plenty of answers.
How did you arrive at those numbers you posted...
I assume the proper way to set pinion angle is measure the transmission slip yoke then measure the rear end drive shaft yoke..These are the numbers you want to go by. Make sure the car is level like it would set in the staging lanes or on the line. Its simple math from there. Like +2.5 slip yoke + -4.5 pinion yoke = a -2 pinion angle.
Cause of pinion wrap on a leaf spring car most look for 4-5 deg nose down (- pinion angle). Were a ladder bar car or 4 link moves very little so they can read much closer to zero. Any positive pinion angle is bad.
Re: Pinion angle shim size question [Re: cupcake] #496370
10/13/09 06:40 PM
10/13/09 06:40 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
Really, not a 2x4 that I have ever seen. If you dont have anything positive to add, please move along.
Re: Pinion angle shim size question [Re: Bob_Coomer] #496371
10/13/09 06:44 PM
10/13/09 06:44 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
bob, I measured like in this diagram. thats where my numbers came from. you could call it 87.5/87.5 on both I guess it depends how you hold the gauge.
Re: Pinion angle shim size question [Re: Joshs68] #496372
10/13/09 06:45 PM
10/13/09 06:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Re: Pinion angle shim size question [Re: Bob_Coomer] #496373
10/13/09 06:48 PM
10/13/09 06:48 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
I will, you beat me but I posted what I did
came from here
http://www.wolferacecraft.com/pinionangle.aspx
is this away acceptable also
Re: Pinion angle shim size question [Re: Bob_Coomer] #496374
10/13/09 06:50 PM
10/13/09 06:50 PM
Hemiroid Offline
Hemiroid  Offline
Read this as well
GAWW! Treed again
Re: Pinion angle shim size question [Re: Bob_Coomer] #496375
10/13/09 06:58 PM
10/13/09 06:58 PM
Boise
Moparteacher Offline
Boise
Does this help?
Your pic is better than mine
Re: Pinion angle shim size question [Re: Moparteacher] #496376
10/13/09 07:12 PM
10/13/09 07:12 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
I did another thread search. I see that this is split into two camps.
Re: Pinion angle shim size question [Re: Joshs68] #496377
10/13/09 08:56 PM
10/13/09 08:56 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
O.K. I rechecked some things. the yoke on the trans or engine centerline is tilted 2.5* down pointing at the rear. The yoke on the rear of the car is tilted 2.5* up. so they are parralel right now. So I need to shim so I have +/- 3* negative so that under power they return to parallel. right?
by the way the MR Gasket pinion shim I have now is a 4* and measures 3/8" on the fat end. NOT exactly a 2x4.....
Re: Pinion angle shim size question [Re: Joshs68] #496378
10/13/09 09:11 PM
10/13/09 09:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes you are now parallel. So put that 4* 2x4 shim in there, for a nose down pinion angle.
In your example both camps methods, would work out exactly to the same pinion angle.
It isnt always like that though, witch is why I aways use the Tranny/Pinion centerline method.
The more accurate camp method!! mike
Re: Pinion angle shim size question [Re: Sport440] #496379
10/13/09 09:20 PM
10/13/09 09:20 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
with the shim that thick does the locating pin for the housing need anything?a longer bolt to reach the axle perch or something?
Re: Pinion angle shim size question [Re: Sport440] #496380
10/13/09 09:40 PM
10/13/09 09:40 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
It has the 4* shim in it now. the thick part of the shim is 3/8"
I also noticed I was getting the same numbers both ways. I think I will put a 6* shim in it. they are 5/8" and that should give me enough to make me happy. I have plenty of bolt head poking up now. not a problem.
Re: Pinion angle shim size question [Re: blownzoom440] #496381
10/13/09 09:49 PM
10/13/09 09:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not in most cases IMO. I have seen some different height locating pins, but most IMO would be plenty long enough for a 4* shim 3/8 thick on the fat side. As its thickness would be half that at the pin.
But it would be something to check.
But, I say, Go ahead with the 2x4 mike
