Re: Alt wiring... Please help
[Re: blownzoom440]
#496107
10/13/09 02:00 PM
10/13/09 02:00 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
i used #4 to be safe.how do you have your car wired for power for shutting it off from the driver seat?
If that question was to me...
The wire from the alt runs to the battery side of the relay, also from the battery side is a smaller wire that provides power to the fuse block, the solenoid is actuated from power provided from the ignition back to the solenoid which in turn delivers power to the starter. The ignition still performs as it would in any other car. I basically used what is provided by Mad Electrical for a remote battery set up.
[Re: GTXKen]
#496108
10/13/09 02:57 PM
10/13/09 02:57 PM
Posts: 3,695 nc
emarine01
nc
The simplest thing to do is run a long large wire < size depends on lenght and amps> to the batt B+ or the batt side of the cut off switch, I am assuming your batt is in the back, the larger the wire and the better the quality will determine voltage drop from the alt, care full wire routing and chafe gear is important , fusing the output wire is up to you depending on how safe you think the run is and the wire used, proper crimp ends and shrink tube is a good idea, I always run agw wire one size larger than the chart recommends and never had low voltage problems, this is the basic simple stupid way to do this, there are many other ways to wire this system just look up the posts
