71 DUSTER RALLY DASH #495768
10/12/09 08:45 PM
10/12/09 08:45 PM
Indy
biged1932 Offline OP
Indy
WILL A 71 DUSTER RALLY DASH GAUGE CLUSTER FIT IN A NON RALLY GAUGE CAR ? DOES ANYONE MAKE A CUSTOM GAUGE CLUSTER FOR A DUSTER ? THANKS FOR THE HELP!!!
Re: 71 DUSTER RALLY DASH [Re: biged1932] #495769
10/12/09 08:49 PM
10/12/09 08:49 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
You will need the entire dash, wiring, and metal framework to put a ralleye dash in a non ralleye car. You will also have to R&R the windshield to make this swap. I have seen custom dash inserts for the non ralleye dash though I can't remember where.
Arno
Re: 71 DUSTER RALLY DASH [Re: biged1932] #495770
10/12/09 09:04 PM
10/12/09 09:04 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Redline makes a dash blank for the 71 dash. You can make a non ralley dash work with a little action. It's not a bolt in but it can be done.
Re: 71 DUSTER RALLY DASH [Re: moparpollack] #495771
10/13/09 01:41 AM
10/13/09 01:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It is best to do this with all correct parts, but you can cut out your standard dash frame. You can also change the frame without removing the windshield. You have to cut the fasteners and reinstall with shorter bolts upsidedown.
