Blower motor removal on 69 charger with a/c #495510
10/12/09 03:55 PM
10/12/09 03:55 PM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
How do I remove the blower motor on a 69 charger with air conditioning? I tried removing the three sheet metal screws on the side of the mounting plate but it didn't seem to loosen anything.
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495511
10/12/09 04:12 PM
10/12/09 04:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It may just be stuck by the weather sealer used.
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495512
10/12/09 05:40 PM
10/12/09 05:40 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Those three little screws are all that holds it.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495513
10/12/09 10:10 PM
10/12/09 10:10 PM
San Jose, CA
San Jose, CA
Thanks guys.
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495514
10/17/09 10:37 PM
10/17/09 10:37 PM
San Jose, CA
San Jose, CA
Could someone post a picture of the removed assembly so I can know which parts to separate?
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495515
10/18/09 09:16 AM
10/18/09 09:16 AM
O
OLD318 Offline
OLD318  Offline
O
Factory A/C on B-body is a total PITA....
If its factory A/C, you need to remove the
blower moter wheel found inside the box inside the car.
Your going to have to remove the lower baffle and the passenger side duct to get to it though.
If you look under the dash you'll see a square-ish
chamber to your right. Push open the door and you will see the blower motor wheel.
There is a tiny clamp which holds the wheel in place (similar to a power steering or fuel
line clamp.)
Take a pair of needle nose pliers and take the
little clamp off. Then slide the wheel forward.
The blower motor should come out afterward.
Be very careful with the blower motor wheel,
Its fins are easily broken. I don't believe there
is an aftermarket replacement for that piece.
FWIW, the factory A/C box on 67-70 B Bodies
are a total PITA. Sometimes your better off removing
the whole box and working on it on a bench than trying to fool with it under the dash.
The factory service manual outlines how to do this very nicely. Its a PITA no doubt!
If your trying to do anything to that box in the car. i.e under the front seat dash
- you have very little room to work...it gets frustrating
really fast especially if the car is a driver and
the front seats are installed.
if this is the case, your sure to get a complete
review of your church vocabulary not only for content
but for clarity!
Good luck.... get the FSM if you don't already have it !
Re: Blower motor removal on 69 charger with a/c [Re: OLD318] #495516
10/18/09 11:01 PM
10/18/09 11:01 PM
San Jose, CA
San Jose, CA
Thanks old318. I removed the cover under the glovebox and can see the wheel. My FSM said to remove the three small screws on the housing and remove the motor and housing as an assembly. But it is still stuck in place tight so I will try your method.
Re: Blower motor removal on 69 charger with a/c [Re: Blue69Charger] #495517
10/19/09 11:45 AM
10/19/09 11:45 AM
Grand Prairie,Texas
Grand Prairie,Texas
IF it's stuck tight it's not the fan. You are stuck to the firewall by the sealer the factory used. Just take a screwdriver or small pry bar and gently pry it away from the firewall. The fan won't hold it in because it doesn't touch anything. All removing the fan does ifs give you more roonm to get the blower motor out once it's loose.
Re: Blower motor removal on 69 charger with a/c [Re: stumpy] #495518
10/19/09 01:33 PM
10/19/09 01:33 PM
calif
cupcake Offline
cupcake  Offline
calif
is the blower under drive or over drive by how much could be a proublem what comp ratio??????
Re: Blower motor removal on 69 charger with a/c [Re: cupcake] #495519
10/19/09 07:06 PM
10/19/09 07:06 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Whaaa???
1MYTGTX
Re: Blower motor removal on 69 charger with a/c [Re: 1MYTGTX] #495520
10/19/09 07:38 PM
10/19/09 07:38 PM
Grand Prairie,Texas
Grand Prairie,Texas
He made an attempt at a joke. Ha Ha .
