Dry sump system ?
#495345
10/12/09 02:22 PM
10/12/09 02:22 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Can you convert a wet sump pan for use in a dry sump system ? I have an aluminum Dan Olson funny car pan that is currently set up with two external lines attached to a single wet sump pick up ?
76 Duster
work in progress
Re: Dry sump system ?
[Re: Edge]
#495347
10/12/09 02:42 PM
10/12/09 02:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sure, I did one but I put a divider wall in it so each pick up had its own 1/2 of the engine
[Re: Edge]
#495348
10/12/09 02:49 PM
10/12/09 02:49 PM
Posts: 901 oh
julian2007
oh
ask a dry sump manufacture rep, depending on how the holes are in the pan you may have trouble with sucking the oil off the wrist pins.Dry sump pans have special tubes with the bottoms machined off so they suck off the bottom of the pan and make the correct vacuum.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: julian2007]
#495349
10/12/09 03:16 PM
10/12/09 03:16 PM
Edge
Alberta Canada
I have heard of problems with pulling oil off the wrist pins but thought this is usually tied to pulling to much vacuum ? Would be great if I could make this pan work with dry sump since it has been modified to fit the tubular k member already.
76 Duster
work in progress
[Re: AndyF]
#495351
10/12/09 03:36 PM
10/12/09 03:36 PM
Edge
Alberta Canada
thanks AndyF, did you ever try the dry sump system with a 4 stage pump ? I am interested in what kind of vacuum the system pulled
thanks
76 Duster
work in progress
[Re: boatracer572]
#495355
10/12/09 08:48 PM
10/12/09 08:48 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
Poster: TS3303 Subject: Re: Dry sump system ?
Andy are you going to add your dry sump pump mount/block off plate to your part list and sell them?
He has I have one sitting on a shelf in one of my cabinets!!
Thanks Tony, any reason it's sitting on the shelf and not the engine?
[Re: TS3303]
#495356
10/12/09 09:03 PM
10/12/09 09:03 PM
Posts: 31,067 Oregon
AndyF
I have a couple of different block plates that I sell. A front entry and a side entry are on the shelf. I have a top entry design that hasn't been released yet but could be built if someone needed it.
https://board.moparts.org/ubbthreads/show...rue#Post5093729
