Re: P0441 Code
[Re: Fluffy]
#495291
10/12/09 02:01 PM
10/12/09 02:01 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Is the car running when you get gas?Thats what usually sets that code when you get gas.Sometimes a bad cap will cause it also.Rocky
Chrysler Firepower
Re: P0441 Code
[Re: therocks]
#495292
10/12/09 02:05 PM
10/12/09 02:05 PM
Posts: 13,049 The Thumb O' Michigan
Fluffy
Automotive STD Guy
Automotive STD Guy
Nope, never have it running. I just replaced the cap not too long ago.
Re: P0441 Code
[Re: Fluffy]
#495293
10/12/09 02:17 PM
10/12/09 02:17 PM
therocks
Niles , Ohio
Do you fill it?Lots of people overfill.That and some pumps are too fast and the emissions setup smells it and pops the light.Rocky
Chrysler Firepower
Re: P0441 Code
[Re: Fluffy]
#495295
10/12/09 02:24 PM
10/12/09 02:24 PM
therocks
Niles , Ohio
Next time put the gas in slow and see if it sets.Not a lot to check unless it sets all the time like everytime its cleared and resets the code withouth gassing up.Did this happen after the cap change?Rocky
Chrysler Firepower
Re: P0441 Code
[Re: Fluffy]
#495297
10/12/09 03:29 PM
10/12/09 03:29 PM
1. faulty fuel cap or... 2. a leak in the miles of tubing.
theres a procedure that uses smoke to test the line(s). expensive and time consuming. good luck.
Re: P0441 Code
[Re: Sub95]
#495299
10/12/09 04:45 PM
10/12/09 04:45 PM
Posts: 186 Kansas, USA
Venomvpr900
Kansas, USA
POSSIBLE CAUSES -EVAP Canister -Wiring Harness Intermittent -EVAP Purge Hose (Canister to Fuel Tank) -EVAP Purge Hose (Solenoid to Canister) -EVAP Purge Solenoid Vacuum Supply -EVAP Purge Solenoid (Leaky/Stuck Open) -EVAP Purge Solenoid (Stuck Closed) Hope this helps ![](/ubbthreads/images/graemlins/wrench.gif)
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver
13.83 @ 96.36 1.98 60 ft
2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
Re: P0441 Code
[Re: Venomvpr900]
#495301
10/12/09 09:38 PM
10/12/09 09:38 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
POSSIBLE CAUSES
Hope this helps
Cool, thanks. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: P0441 Code
[Re: Venomvpr900]
#495302
10/12/09 09:43 PM
10/12/09 09:43 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
POSSIBLE CAUSES
Hope this helps
![](/ubbthreads/images/graemlins/iagree.gif)
That code is not set by a loose gas cap or a leak in the system. (YOu would have leak codes then ie gross leak detected, small leak detected, etc..)
That code is usually set by a problem in the purge system.
If you pull off the canister and solenoid, you will likely find it is full of dirt. It may work if you clean it, but you may have to replace it all, or just some pieces.
