ignition #495266
10/12/09 12:29 PM
10/12/09 12:29 PM
Kamloops B.C. Canada
E
ebodyfrank Offline OP
E
have a problem with a 72 challenger car wont start good starter good coil.I jumped out the safety nutural switch and when i put the key in the start position nothing but when i let go of the key it starts but this is backwards should start when you turn the key to the start position (ignition parts are all brand new)without jumping out the safety it wont start.
Re: ignition [Re: ebodyfrank] #495267
10/12/09 12:35 PM
10/12/09 12:35 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
check to see what the voltage reading is at both sides of the ballast.
Re: ignition [Re: Dakota_Don] #495268
10/12/09 12:50 PM
10/12/09 12:50 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Maybe your ignition switch is worn-out/bad?
Re: ignition [Re: Dakota_Don] #495269
10/12/09 01:06 PM
10/12/09 01:06 PM
E
E
cheched out ballast green wire with red strip 10.41v double brown 4.52v blue 10.36v black10.36v
Re: ignition [Re: ebodyfrank] #495270
10/12/09 01:07 PM
10/12/09 01:07 PM
E
E
ignition switch is new
Re: ignition [Re: ebodyfrank] #495271
10/12/09 01:16 PM
10/12/09 01:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
wired wrong??
Re: ignition [Re: Dodgem] #495272
10/12/09 01:46 PM
10/12/09 01:46 PM
E
E
what is wired wrong ? had no problem with the car has started every time with no problems till now
Re: ignition [Re: ebodyfrank] #495273
10/12/09 01:59 PM
10/12/09 01:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ill say it again.Just because its new dosent mean its good.Check to see that when in crank it has power to the relay.That and make sure it is powering the ballast when its cranking.Rocky
Chrysler Firepower
