727 problem, help figure it out with me
#494833
10/12/09 08:26 AM
10/12/09 08:26 AM
Posts: 4,573 ...gently down the stream
LAR_414
Friend of mine is going to be dropping off his 727, so I can find a problem.....so what do you think I should look for?
9 or 10" PTC "street" converter behind 383 that runs high 12's in 65 coronet street car. Cheetah Rev Man valve body.
About 3 years ago, I put new clutches and bands in this trans and it has been running fine for years. Now it's having an issue.
Taking a long time to "move", and a long time to get into gears when shifting, street driving or WOT. It's like the pump isn't pumping enough fluid or the converter is toast.
On jack stands, it takes a MINUTE to get the wheels to turn when first putting it into gear. From there, it's very sluggish getting into gears.
He has taken it out and dropped the pan....no broken parts in the pan, and fluid looks relatively ok, and the filter doesn't seem plugged up or anything.
What's your guess,....I'm thinking it's the converter or the pump.
Re: 727 problem, help figure it out with me
[Re: 440Jim]
#494840
10/12/09 11:36 PM
10/12/09 11:36 PM
Posts: 3,095 Idaho
Runner
Idaho
It would have been nice to have swapped the valve body with a known good one before pulling the trans out of the car. Hopefully you will find a broken ring or damaged seal. Check the surfaces the rings ride on and the groove as well.
I agree an air test is a good idea before tearing it apart. Just like measuring input shaft end play, basic checks first.
back in the early 90s i tore a trany apart twice looking for a problem, i finally tried a different valve body and that fixed the problem. the symptoms were different though.
