Master cylinder heat shield ? #494405
10/11/09 07:35 PM
10/11/09 07:35 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Anybody make them for the standard 4-bolt MC? I know they're available for the 2-bolt style; can a 2-bolt be tweaked or modified to work with the 4-bolt style?
Re: Master cylinder heat shield ? [Re: topside] #494406
10/11/09 11:12 PM
10/11/09 11:12 PM
AndyF Offline
AndyF  Offline
The heat shield that Mancini Racing carries has the mounting holes slotted a small amount so that it will fit either two bolt or four bolt master cylinders.
Re: Master cylinder heat shield ? [Re: AndyF] #494407
10/12/09 01:00 PM
10/12/09 01:00 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, Andy.
