Re: help needed with altenator and regulator
[Re: jbcuda]
#494213
10/11/09 05:41 PM
10/11/09 05:41 PM
Posts: 25,991 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you eliminate the large black wire the ammeter won't work, current needs to flow in both directions to show charge/discharge on the ammeter and eliminating the black wire will only allow the ammeter to show discharge.
[Re: jbcuda]
#494215
10/12/09 03:50 PM
10/12/09 03:50 PM
John_Kunkel
Rio Linda, CA
If you want the ammeter to work you have to hook it to the alternator lug.
[Re: John_Kunkel]
#494216
10/12/09 07:47 PM
10/12/09 07:47 PM
RapidRobert
with a wire directly from the alt to the batt the ammeter will read but not correct. I'd suggest an 8ga wire between batt/alt w a 12ga fusible link to protect that line and connect the 2 large wires on the ammeter together on one stud of the ammeter & add a voltmeter via switched 12V though I too am old school & I like my ammeter (& an added voltmeter also)
