Separating inner/ outer wheel houses? #494009
10/11/09 01:06 PM
10/11/09 01:06 PM
Indiana
68_661charger Offline OP
Indiana
Are the inners/ outers seam welded together like a gas tank? If so is grinding the outer wheel house flange the best way to remove the outer?
Re: Separating inner/ outer wheel houses? [Re: 68_661charger] #494010
10/11/09 01:15 PM
10/11/09 01:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Drilling out the spot welds is the best way.
Re: Separating inner/ outer wheel houses? [Re: 68_661charger] #494011
10/11/09 01:17 PM
10/11/09 01:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
They are spot welded on the flange with a sealer between the panels.. I've used an air chisel with a flat blade with good results..
