Re: New motor build
[Re: Mopar_Ray]
#493849
10/11/09 09:30 AM
10/11/09 09:30 AM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
sounds good. the new 337 m-1 is a max wedge intake.it will fit under the hood also.i have two of them,one on a 580" motor....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New motor build
[Re: RemCharger]
#493852
10/12/09 08:44 AM
10/12/09 08:44 AM
Posts: 512 Illinois
Mopar_Ray
Illinois
Why not go with -1's? I'm at the same stage, I put my -1s on my 383 with the same FT cam etc, and basically put it in the high tens. My 499 stuff is sitting in the corner, waiting.. I wouldn't get a cam yet, wait till its going together. You're direction could change a bit by the time you're building. Should add a lot of power to what you have.
I assume you mean 440-1 vs EZ-1? The 440-1s are another possibility. Does anything need to be done to the block to run the 440-1s?
