New motor build #493848
10/11/09 09:24 AM
10/11/09 09:24 AM
Illinois
Mopar_Ray Offline OP
Illinois
Planning new engine build. Looking for opinions. Planning on building my 440 into an Indy headed 500+ stroker. Can't afford to do the whole thing at once, so I'm thinking of building the entire top end this winter. Thinking of using a ported set of Indy EZ-1 heads. TTI 2 1/8 step headers. A Comp Cams solid roller cam. Don't think my M-1 intake will work with the max-wedge heads? and either my Quick fuel 950 or stepping up to a dominator.
Then next winter, I'll have the stroker short block built and put all the new top end on it.
My eventual goal is to get my 70 Challenger to run low 10's
How does my plan sound so far?
Re: New motor build [Re: Mopar_Ray] #493849
10/11/09 09:30 AM
10/11/09 09:30 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
sounds good. the new 337 m-1 is a max wedge intake.it will fit under the hood also.i have two of them,one on a 580" motor....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New motor build [Re: Mopar_Ray] #493850
10/11/09 12:19 PM
10/11/09 12:19 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Why not go with -1's?
I'm at the same stage, I put my -1s on my 383 with the same FT cam etc, and basically put it in the high tens. My 499 stuff is sitting in the corner, waiting.. I wouldn't get a cam yet, wait till its going together. You're direction could change a bit by the time you're building.
Should add a lot of power to what you have.
Re: New motor build [Re: RemCharger] #493851
10/11/09 12:29 PM
10/11/09 12:29 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I have a simular combo. 500" indy ez-1's by compu-flow, comp roller. you're gonna have to get the indy intake or one with max-wedge ports. my car w/ me weighs 3400. I went with the ez's due to being an A body. she put down a 10.34 @ 129.5 yesterday and that's only the 5th run on the motor.
Re: New motor build [Re: RemCharger] #493852
10/12/09 08:44 AM
10/12/09 08:44 AM
Illinois
Illinois
I assume you mean 440-1 vs EZ-1? The 440-1s are another possibility. Does anything need to be done to the block to run the 440-1s?
Re: New motor build [Re: Mopar_Ray] #493853
10/12/09 11:55 AM
10/12/09 11:55 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Either EZ-1s or 440-1s fully ported, 280 at .050 roller. 2.25 intake valves. 1150 Dominator on 3x manifold. 12.5 to 1 CR. dual line oil system and T&D rockers. That should get you down to 10.0s.
Re: New motor build [Re: B1Fish540] #493854
10/12/09 08:31 PM
10/12/09 08:31 PM
Illinois
Illinois
What are the pro/cons between 440-1s & EZ-1s? And thanks all for the input!
Re: New motor build [Re: Mopar_Ray] #493855
10/13/09 12:40 AM
10/13/09 12:40 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The ez's were made to fit in the smaller a body engine compartment. So the -1's have a taller ex port which can make more power. My thoughts are, if you can fit them, why not use 'em?
Re: New motor build [Re: Mopar_Ray] #493856
10/13/09 01:16 AM
10/13/09 01:16 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Edelbrock makes a max wedge port victor intake for the 440. I think they also have a super victor with a dommy flange. For what it's worth, I did a little bowl blend and blended the cnc'd intake entrance and got 355 cfm out of a set of victor Max wedge heads, stock valve. The 2.200 valve is too small for the bowl of these heads so I can't wait to see what they'll do if I cut 'em for a 2.250 valve.
They still oil through the head as well. If that's something that concerns you. Get the T&D rockers if you choose to go that route.
