Re: CS thermoquad ?
[Re: ademon]
#493783
10/11/09 08:22 AM
10/11/09 08:22 AM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
The Competition Series carbs were manufactured(1969)before the first oem(1971) Thermoquads. Two versions of the CS carbs were made. An 850 cfm and a 1,000 cfm. For the first year, the CS carbs had press-in jets that were held in place with an o-ring, then the switch was made to a screw-in style jet. These are aftermarket performance carbs that are 'air metered' carbs.
If you are talking about the 9800 series T.Q., these are all 'solid fuel' metered carbs that only have floats, accelerator pumps, pump well cover and transfer tubes in common with the CS series carbs. These are also aftermarket replacement carbs and are 800 cfms. The choke system is attached to the base of the carb and requires a 12 volt source; the choke is much like the current choke on the Edelbrock Performer and Thunder series carbs and is unique to these carbs. This means the choke will not fit any other models with one exception: the Ford 460 '74 T.Q.'s(this was a heat activated choke from manifold heat)without the 12 volt assist. There are 4 versions: 9800, non egr for Gm products(Q-jet replacement) 9801, non egr for Mopar, replaces all cfm's, 9810, egr for GM, 9811, egr for Mopar. All are 800 cfm's.
All 9800 series carbs were known as SuperQuads and used a '74 Ford base with a Mopar throttle lever, a '75 top and a '78-up bowl.
Here are pics of both models and note that the CS series carbs have large rectangular flats on the top with Carter logos and the front vent stack is part of the top casting. **Interesting note is that the one year only(first oem T.Q. use) 1971 340 carbs were based on the screw-in jet CS carbs but was 800 cfms.
A 1,000 cfm CS T.Q. showing only a single primary booster ring and no taper to the primary bores; just 'straight-through' bore:
Re: CS thermoquad ?
[Re: ademon]
#493788
10/17/09 08:41 PM
10/17/09 08:41 PM
Posts: 2,099 oberlin, Ohio
Rapid340
oberlin, Ohio
I ran an 11.12 with an OEM 72 400 thermoquad I paid $10 for at a swap meet. I did use larger seats and did a good bit of tuning. Got to admit, I have soft spot for the comp. series though. ![](/ubbthreads/images/graemlins/drive.gif)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: CS thermoquad ?
[Re: Rapid340]
#493790
10/17/09 08:50 PM
10/17/09 08:50 PM
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
Jeff, did you sell the bb a radiator? I did get a radiator for the Demon to suit the 440 swap.
ThermoQuads:stock, street/strip and race;
800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's.
New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating.
Carbs bought and sold. Consulting on pre-purchases
so you get the right carb the first time.
Re: CS thermoquad ?
[Re: ademon]
#493791
10/17/09 08:54 PM
10/17/09 08:54 PM
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
Is there any advantage in running a 850 cs over a reg 6000 series 850 cfm t-quad. does't seem like any
The CS 850 might have a slight advantage over an oem early 850 assuming the jetting is correct. But when you increase air flow and re-jet the oem 850, the CS would probably be inferior in performance.
Re: CS thermoquad ?
[Re: ademon]
#493793
10/17/09 09:17 PM
10/17/09 09:17 PM
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
I don't feel so bad now, I lost out on a auction for one, I already have a 6321 (73 400)ready to go with some mods and the good 1966 rods. i guess my 4973 is close to the CS anyway. Talked to Jeff about manifold porting, Thanks Jeff
The 6321 is a great performer! You will like it. The 4972/4973 are both based on the later CS 850 cfm version. Same jet style and metering rod assembly/rods. And the top bowl gasket is the same on both CS versions and the 4972/4973.
