Rear Lower Shock Flops Around Where It Bolts To Housing #493773
10/11/09 02:14 AM
10/11/09 02:14 AM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
My 98 Grand Cherokee rear lower shocks flop around on the 2 lower bolts on each side.I am speaking of the part where the shocks mount on the rear end housing,and where the bolt goes through to attach the shock.The rear shocks are only a year old,bolts are tight and the bushings are good. Anyways,the noise drives me nuts,and when I'm underneath it and push up on the undercarriage,you can see it plain as day the lower part of the shock jumps around the bolt. What can I do about this? Go to a bigger diameter bolt? Appreciate any help. Thanks
'71 383HP FJ6 Charger SE
Re: Rear Lower Shock Flops Around Where It Bolts To Housing [Re: 71 FJ6 Charger] #493774
10/11/09 02:39 AM
10/11/09 02:39 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Or a smaller-diameter bushing.
Could you have been sold the wrong shocks?
Re: Rear Lower Shock Flops Around Where It Bolts To Housing [Re: 71 FJ6 Charger] #493775
10/11/09 02:49 AM
10/11/09 02:49 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Do the shocks have poly bushings? Did you get the metal sleeve to insert into them that the bolt slid into?
Ride eternal, shiny and chrome
Re: Rear Lower Shock Flops Around Where It Bolts To Housing [Re: 71 FJ6 Charger] #493776
10/11/09 08:53 AM
10/11/09 08:53 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
What kind of shocks are they, I recently changed mine on my 98 GCL to KYB gas adjusts'. They fit tight and ride great..Are your bushing washers there?
