Re: 39 Dodge
[Re: B1Fish540]
#493114
10/10/09 09:47 PM
10/10/09 09:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, drag racing only require that the car goes straight. Just about any front suspension should be able to do that.
Now if you're asking can it handle Watkins Glen, no. But the front suspension wouldn't be the only reason. With a couple of mods it'll handle as well as any run of the mill family type car.
Basically, put discs on it and relocate the front shock is the majority of it. If you want it's also possible to put a power rack in them. But that would probably necessitate a different steering column. Which is probably a wise thing.
Re: 39 Dodge
[Re: Supercuda]
#493115
10/11/09 10:19 AM
10/11/09 10:19 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Lowering also can help. A lower center of gravity helps handling, and they are pretty tall stock. There are dropped uprights available. Springs and a sway bar tuned to modern rubber will help too. Just depends on how much you want to change and spend. Here's a lot of good info, make sure to read the article about half way down. http://shadowmtkustomz.blogspot.com/
