Carb Fuel Smell
#492864
10/10/09 02:45 AM
10/10/09 02:45 AM
Posts: 217 New Port Richey, Florida
Wolfe440
Every time I come back from driving my 440 six pack Challenger and park it in the garage, 15 min or so later I smell fuel fumes. So for the last several times when I finish driving it I do an absolute check of everything and find no leaks, just the smell. Tonight I came home about 2am, garage started to smell soon after. This time in the absolute quiet of 2am I could just hear a soft noise from the carbs. I soon identified the noise was coming from fuel boiling in the bowls...hence the likely source of my fumes. The car runs at a perfect 170 and never overheats, everything is new and perfect shape. Its the cast iron intake, has the intake gaskets with the heat crossover blocked. Any ideas as to what I can do to stop this? Does anyone make heat spacers for these carbs? Thanks Wolfe
Re: Carb Fuel Smell
[Re: Wolfe440]
#492867
10/10/09 07:19 AM
10/10/09 07:19 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
What year car? Are you sure the fumes are from the carbs? Could be the gas tank vents spilling a small amount a fuel if it does not have an evap system.
Re: Carb Fuel Smell
[Re: torkrules]
#492868
10/10/09 11:42 AM
10/10/09 11:42 AM
Wolfe440
Its a 1970 Challenger. Its not venting, that was also my first suspicion, I've had problems over the years there before, but no evidence of a problem this time. Your nose leads you straight to the carbs where its very strong. Take the filter off and it really hits you. No leaks anywhere, I even took the carbs off and looked for any problems, none found. I have the standard metal fuel line branching to each carb, its real close to the iron intake and picking up a whole lot of heat. Last night it was super hot when I checked it, could not even touch it but for a second. I'm sure this preheating of the fuel just before its delivery is not helping. When the boiling stopped so did the smell. I found some .250 thick base gaskets, and I am going to wrap the fuel line with some asbestos and see if it this helps. Thanks, Wolfe
Re: Carb Fuel Smell
[Re: D_C]
#492869
10/10/09 07:20 PM
10/10/09 07:20 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Depending on your air-cleaner setup and hood clearance, you should be able to find Phenolic spacers, and/or mount a heat-deflector (sheet-aluminum) placed under the carbs.
If you can't buy pre-made ones, you could fabricate your own.
I tried to install one of these on my 440 4-bbl but there is not enough clearance for the air grabber setup.
