1969 charger oil sending unit.... #492835
10/10/09 01:35 AM
10/10/09 01:35 AM
long island
autodynamics Offline OP
long island
i replaced the one i had a few years back read 50-80lbs that sending unit went bad....to close to the headers and the center pin became loose and gave me erratic reading now.... the new ones i got read 20-40lbs for the same listing.... is there more than one sending unit for the motors?? 318-426? thanks pete
Re: 1969 charger oil sending unit.... [Re: autodynamics] #492836
10/10/09 08:26 AM
10/10/09 08:26 AM
Lowell Mi
Rat_Exterminator Offline
Lowell Mi
just got my 69 charger on the road, way low readings showed 10-20#, went thru dash, replaced voltage regulator, finally swapped out sending unit and went right to 40-60#. had wrong unit on, one meant for idiot light not gauge, that could be your problem too, similar symptoms. Greg
Re: 1969 charger oil sending unit.... [Re: Rat_Exterminator] #492837
10/10/09 10:35 AM
10/10/09 10:35 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Mine runs close to 60 lbs when cold and 40 when warm. What unit do you have the Melling HV ?? Also depends on the type of oil you use. On my 70 440 I ran straight 50 and came out with 70 cold and 60 warm. While my 69 runs 20w50
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 1969 charger oil sending unit.... [Re: autodynamics] #492838
10/10/09 10:45 AM
10/10/09 10:45 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Too close to the headers? On a mopar?
Re: 1969 charger oil sending unit.... [Re: buildanother] #492839
10/10/09 11:29 AM
10/10/09 11:29 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: 1969 charger oil sending unit.... [Re: OzHemi] #492840
10/10/09 01:10 PM
10/10/09 01:10 PM
Madison WI
Sublime69 Offline
Sublime69  Offline
Madison WI
That's what I was thinking. I would put a mechanical gauge in it and never worry about it, unless you're commited to use the factory gauges.
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
Re: 1969 charger oil sending unit.... [Re: Sublime69] #492841
10/10/09 01:25 PM
10/10/09 01:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With the sending unit at the top rear center of the block I don't see how the headers are anywhere near the sender. Maybe the OP can explain it a bit better.
Re: 1969 charger oil sending unit.... [Re: stumpy] #492842
10/10/09 06:32 PM
10/10/09 06:32 PM
long island
long island
ohhh sorry im running a late model motor...sending unit is on passenger side near the header...
Re: 1969 charger oil sending unit.... [Re: Rat_Exterminator] #492843
10/10/09 06:42 PM
10/10/09 06:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Guage takes a big bell shaped sender and lite is the little flat sender.
Running a late model - Late model what: All the later small blocks the unit is in the same liocation in the top rear of the block next to the distributor..
Re: 1969 charger oil sending unit.... [Re: autodynamics] #492844
10/10/09 08:51 PM
10/10/09 08:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No its not. Better post a pic of what you are calling an oil sending unit.
