Re: Want 400-4 timing dead on 10 deg before installation
[Re: wh23g3g]
#492716
10/09/09 10:41 PM
10/09/09 10:41 PM
RapidRobert
I would bring the timing marks slowly up to 10BTDC & not turn it backwards (if you go past turn it back to 20BTDC then creep up on it again) & plugs out for this helps. With the vac can pointed roughly where you want it and a reluctor tooth lined up with the magnet slot continue to move the housing slightly (CW) so the reluctor tooth is a hair past being centered on the magnet.
[Re: wh23g3g]
#492719
10/10/09 09:20 PM
10/10/09 09:20 PM
Posts: 3,884 Oregon
hooziewhatsit
Looking at the valves, they're in order by EIIEEIIE.
Crank it over and watch the intake valve on the #1 cylinder. After it closes, bring the damper to TDC. That will be TDC on the compression stroke.
Now put the distributor/intermediate shaft in where ever you want, and the rotor will be pointing to the terminal for #1. Then go in normal firing order from there.
[Re: hooziewhatsit]
#492720
10/10/09 10:47 PM
10/10/09 10:47 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
rotate the engine over, paying attention to the valves. there'll be a period of time when neither valve is moving, the first valve that moves will be the exhaust, then the intake. TDC will occur when the exhaust is closing and the intake is opening (split overlap) That's not the one you want. After the intake opens and closes, pay attention to coming up on TDC and set the damper to 10 BTDC. Now mark the distributor housing where your number one wire is and make sure the rotor is pointing in that direction. Then make sure the reluctor is lined up with the point on the magnetic pickup, if it's a mopar unit. If it's an MSD or Mallory unit, go until it's halfway past being lined up. It'll fire right up if you have fuel.
