383 vs 383 HP Main Bearing Caps #492645
10/09/09 07:50 PM
10/09/09 07:50 PM
California
darkrider2 Offline OP
California
Did they use the same caps on high performance engines or did they use different caps. The reason I ask is because I sold a 383 block today to a guy and after his 2.5 hour commute back to his house he called me and said he wanted the main bearing caps so he didn't have to line bore it. I have two 383's and I found one complete set and 3 of the 5 of the other set.
Re: 383 vs 383 HP Main Bearing Caps [Re: darkrider2] #492646
10/09/09 08:02 PM
10/09/09 08:02 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The caps were the same on all of them. Regardless, if the caps came off of a different block than what he is using, he will HAVE to line bore it.
Re: 383 vs 383 HP Main Bearing Caps [Re: forphorty] #492647
10/09/09 08:43 PM
10/09/09 08:43 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Caps are the same, but any caps off of a different engine will need to be line bored to work with this engine.
Re: 383 vs 383 HP Main Bearing Caps [Re: dave571] #492648
10/10/09 12:32 AM
10/10/09 12:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
He is looking for the original caps from that engine.
Re: 383 vs 383 HP Main Bearing Caps [Re: 6bblgt] #492649
10/10/09 01:30 AM
10/10/09 01:30 AM
California
California
Thanks guys. The guy ended up being really cool about it an I'm going to mail him both the complete and the partial set. I was just trying to save the guy money, being tough times and all.
