timing for a mild 360 #492587
10/09/09 05:36 PM
10/09/09 05:36 PM
NE Oklahoma
71valiant Offline OP
NE Oklahoma
360 stock pistons
headers
airgap- carter 625 afb
I was running it at 35 but it was hard to start after it got hot. I set it back down to 30 and it starts alot better hot.
Where do yall run your timing?
Re: timing for a mild 360 [Re: 71valiant] #492588
10/09/09 06:37 PM
10/09/09 06:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I run 34 on the street 360 and it is fine. They are all going to be different. Mine has a Crower 267/271 cam in it with stock pistons and headers. Try it at 33 and see what happens.
Is your distributor recurved so that the mechanical advance is fully advanced at the desired RPM. If not if your are measureing 35 degrees at say 25 hundred you will have too much initial becaue the advance is not fully extended and still advancing at a much higher RPM.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: timing for a mild 360 [Re: 71valiant] #492589
10/09/09 07:21 PM
10/09/09 07:21 PM
35 total is making your initial too much & causing the labored cranking. I'd shorten the slots so you can start at ~10BTDC (depending on your cam) & still maintain 35 total(vac adv disconnected/plugged).
Re: timing for a mild 360 *DELETED* [Re: RapidRobert] #492590
10/09/09 07:33 PM
10/09/09 07:33 PM
Upper Midwest
Upper Midwest
Post deleted by MoparforLife
Re: timing for a mild 360 [Re: MoparforLife] #492591
10/09/09 07:35 PM
10/09/09 07:35 PM
NE Oklahoma
NE Oklahoma
I agree with the too much initial but for the reason I stated above. I have set a lot stock and higher compression engines at 35 total with 15 initial and not had a problem with hard warm starting. I haven't heard yet if the distribor is a recurve MP model or a stock distributor. If stock and testing for total at a low RPM will/may give a lot more initial thaan 15.
This is stock electronic. I tested it at idle.
Re: timing for a mild 360 [Re: 71valiant] #492592
10/09/09 07:39 PM
10/09/09 07:39 PM
360 stock pistons
headers
so like 7.5-8.0:1 cr in that 360? run as much initial
as you can and limit the amount of mech. advance. mabey try 15-17deg initial and 20deg mech. should get you
where you need to be. that hot start prob could be many things not
related to timing.
Re: timing for a mild 360 #492593
10/09/09 07:47 PM
10/09/09 07:47 PM
NE Oklahoma
NE Oklahoma
360 stock pistons
headers
related to timing.
Forgot to add it has a 480/480 lift 292/292 duration 230@.050 cam. I put a mopar thin head gasket. I must have atleast 8:1 CR
Re: timing for a mild 360 [Re: 71valiant] #492594
10/09/09 08:00 PM
10/09/09 08:00 PM
360 stock pistons
headers
related to timing.
Forgot to add it has a 480/480 lift 292/292 duration [Email]230@.050[/Email] cam. I put a mopar thin head gasket. I must have atleast 8:1 CR
that cam will bleed off ALOT of dynamic cr. good luck with that. TIMING is NOT gonna fix it.
Re: timing for a mild 360 #492595
10/09/09 08:08 PM
10/09/09 08:08 PM
Upper Midwest
Upper Midwest
We have no idea what the initial is unless I missed something, we also don't know at what RPM he is setting the total at or if the advance has had the sprngs modified to bring the total in earier than a stock distributor.
If it hasn't the initial may be too much in order to get the 35 total at a low RPM. Stock advance will be know where near fully advanced at a lower RPM so alot of initial will be need to make up the difference + it will still be advancing well past that mark.
Re: timing for a mild 360 [Re: 71valiant] #492596
10/09/09 08:10 PM
10/09/09 08:10 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You had 35 degrees at idle? If so, and you have a stock distributor, you probably have 50+ total. Too much.
Re: timing for a mild 360 [Re: forphorty] #492597
10/09/09 08:31 PM
10/09/09 08:31 PM
Upper Midwest
Upper Midwest
Even if he checked the total of 35 degrees at 2500 it would still have way too much initial because it would still have a lot of advance to go, requiring the initial to be upped to make up for the advance that the mechanical advance has not been used yet.
To get a true total advance at a lower RPM the distributor mechanical advance must be recurved.
Re: timing for a mild 360 [Re: MoparforLife] #492598
10/09/09 08:36 PM
10/09/09 08:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Way too much timing at idle. You are checking it with the vacuum disconnected and plugged aren't you? I would think 15-18* at idle with 35* at 2500rpm.
Re: timing for a mild 360 [Re: stumpy] #492599
10/09/09 08:52 PM
10/09/09 08:52 PM
Upper Midwest
Upper Midwest
Needs a recurved distributor to do it though or like I said above the initial will have to make up for the lack of the mechanical not being fully advanced.
Re: timing for a mild 360 [Re: MoparforLife] #492600
10/09/09 08:55 PM
10/09/09 08:55 PM
timing isnt gonna help. he has waaaaay to much cam!
Re: timing for a mild 360 #492601
10/09/09 09:14 PM
10/09/09 09:14 PM
NE Oklahoma
NE Oklahoma
It runs good. Very streetable motor. I've run a 13.20@102 at the track.
Re: timing for a mild 360 [Re: 71valiant] #492602
10/09/09 09:18 PM
10/09/09 09:18 PM
Upper Midwest
Upper Midwest
It runs good. Very streetable motor. I've run a [Email]13.20@102[/Email] at the track.
I have seen a lot more cam than that run great in a low compression small or big block.
Re: timing for a mild 360 #492603
10/09/09 09:20 PM
10/09/09 09:20 PM
NE Oklahoma
NE Oklahoma
I think it really does need a recurved distributer.
Re: timing for a mild 360 [Re: 71valiant] #492604
10/09/09 09:44 PM
10/09/09 09:44 PM
well i bow down to you guys who run big cams and no compression. takes big kahunas to give up a second in ET (give or take a few tenths).
Re: timing for a mild 360 #492605
10/09/09 10:25 PM
10/09/09 10:25 PM
Upper Midwest
Upper Midwest
That's not a very big cam. IMO It's got some duration but not a whole bunch of lift.
I was running low 12.0's with 485/495 & 284 duration with stock pistoned, cast unported 1.88 valve heads, LD4B intake and 750 Holley. Went to KB107 pistons, LD340 with Chuck Nuytenn prepped 750 and consistant low 11.70's. Not a second by a long shot.
Added Hughes stage 1 heads and cam 11.75 true calculated compression, shed a bunch of weight and still haven't gained said second.
Re: timing for a mild 360 [Re: MoparforLife] #492606
10/09/09 10:37 PM
10/09/09 10:37 PM
big enuff cam for the DYNAMIC cr. i also said give or take a few tenths.
my example: and 8:1 400 bbd went 14.20's. did nothing for the next
season except up the cr to 9.75 and went 13.0's. that was also
with a 230 cam. mpg's went up too. go figure.
but hey... each combo is different. but it all boils down to
the tuner. no need to chase your tail when you dont hafta.
