ATI pro glide
#491948
10/08/09 07:44 PM
10/08/09 07:44 PM
Posts: 624 Baltimore,MD
lowbudget
mopar addict
mopar addict
Baltimore,MD
Hello, I was wondering if any of you guys has used the ATI pro glide with a Small Block Mopar with any luck. I bought the glide with the Super Case, tailhousing, sfi bellhousing and adapter kit (sfi flexplate and crank adapter). The problem is that the converter will not go far enough into the transmission to bolt it altogether. I get a measurement of 1 1/2" from the edge of the flexplate (tranmission side) to the block. However, i only get a measurement of 3/4" from the mounting pads of the converter to the bellhousing, see the problem? I went so far as to take the trans and converter to Ati to see if maybe I was just not getting the converter in there far enough. Well, they cant seem to get it in there any better either but measured the converter inside and out and couldnt find a problem with it. they pulled one of their glide converters they had lying around (im using a compettitors) and tried to install it, it gave us maybe an 1/8" but not enough. Im just seeing if any body has had a similar experience like this because they seem clueless and I sure as hell am ...of course there not gonna say its anything with their trans and that might be true? This thing is brand new as well as the converter. Hell even the starter (Mopar Denso mini)will not sit flush with the converter and flexplate installed, their response was that the bellhousing was designed with the original starter in mind and that mine will have to be shimmed...OK who would by a trans of this caliber and use a 35yr old starter? Any sugestions?
Post deleted by Defbob
[Re: lowbudget]
#491955
10/09/09 08:39 AM
10/09/09 08:39 AM
Re: ATI pro glide
#491956
10/09/09 09:02 AM
10/09/09 09:02 AM
lowbudget
mopar addict
mopar addict
Baltimore,MD
is there any chance that you are not seating the converter properly ? maybe your not getting the converter seated and your hitting the pump rotor ?
I guess that could a potential problem, but I hope not...remember I even took the trans and converter to the "professionals" at ATI yesterday and they couldnt figure it out. They just want to blame it on the converter but couldnt find no problems with it after they measured it (both internally and externally). I had three different tech/salesguys out in the parkinglot trying to get this dam thing in further and spent 20min on the phone with them
Re: ATI pro glide
[Re: lowbudget]
#491957
10/09/09 09:19 AM
10/09/09 09:19 AM
Posts: 2,175 Duloc
The Shadow
Duloc
Hmm, you might be onto something there. What would the difference in the converter be if it was made for a mid-plate? Is the snout longer or something?
Ya, the snout is typically 1/8 longer
[Re: lowbudget]
#491960
10/09/09 10:23 AM
10/09/09 10:23 AM
[Re: lowbudget]
#491963
10/09/09 11:46 AM
10/09/09 11:46 AM
Re: ATI pro glide
[Re: lowbudget]
#491965
10/12/09 02:58 PM
10/12/09 02:58 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Flexplate on backwards? Dont rule out the converter. Lords knows I have had many issues with that brand and hub and lug placement.
