Is there a "BEST"Challenger rear quarter patch panel? #491736
10/08/09 02:42 PM
10/08/09 02:42 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I'm looking to buy some rear quarter panel repair patches.
I need the small lower area in front of the driver's rear wheel and the lower quarter panel patch for the passenger side.
I don't see any patch panels listed from AMD, only full quarter panels.
I do see some on E-bay and at some other vendors's sites and there seems to be a big difference in price.
Are all these patch panels made by the same company or is there some that are thicker metal and fit better?
Thanks.
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: KillerBee] #491737
10/08/09 02:48 PM
10/08/09 02:48 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I bought AMD lower rears from Stephen's Performance for my 70 Challegner about 2 months ago. They look really good. I did notice the rear side marker area is just slightly larger than the original holes so I'm going to ask the body guy to make sure he keeps my Original marker cut outs when he put's in the panel. All of my rust is very low on the panel and should not be a problem.
My body guy says he will just make the patch panels for the lower front (in front of the rear wheels) area.
Joe
65 Barracuda
70 Challenger
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491738
10/08/09 03:16 PM
10/08/09 03:16 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks Joe.
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: KillerBee] #491739
10/08/09 03:59 PM
10/08/09 03:59 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Ok Kevin. Here is a pic of the whole panel.
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491740
10/08/09 04:01 PM
10/08/09 04:01 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Here is a pic to give you a better idea of where it will end on your car. You can see I have some rust that it will not cover and will have to deal with. I know I had seen some pics in the past of a longer panel that went up over the wheel further but I don't think the quality of it would be as good as this. This is panel is a good thickness and weight.
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491741
10/08/09 04:03 PM
10/08/09 04:03 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Here is a pic of the light area with an inset of my original. It may be hard to see but you can see the curve of the lines at the recess on the new panel aren't as tight as the original. The marker really doesn't move around in the original opening but I can slide it up and down and side to side a little in the AMD panel.
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491742
10/08/09 04:04 PM
10/08/09 04:04 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Finally, I noticed that the bottom of the lip (where I marked in yellow) is narrower on the patch than on the original.
Joe
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491743
10/08/09 04:28 PM
10/08/09 04:28 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks for the pictures that's exactly what I was hoping to see.
This is the patch panel that I've been looking at so far.
Do you remember how much the patch panel you bought cost?
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: KillerBee] #491744
10/08/09 04:47 PM
10/08/09 04:47 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
The panel you pictured is the one I saw originally and I like the way it goes up over the wheel more BUT don't think it is made as well as this.
The AMD panels are 170.00 each. You can see if they have them and if they will meet you at a nearby car show. That way you can save some shipping. That is what I did.
Joe
Re: Is there a "BEST"Challenger rear quarter patch panel? [Re: jrwoodjoe] #491745
10/08/09 05:03 PM
10/08/09 05:03 PM
N.E. Ohio
K
K
N.E. Ohio
I was thinking from the price and supplier the patch I pictured is probably not very good quality.
From what I can see I'm only going to need the very bottom of the quarter panel, the rest is real nice.
I wonder if AMD makes just the very bottom.
