Re: Dumb Q but does it matter what brand truck Dana 60
[Re: megajoltman]
#491527
10/08/09 03:01 PM
10/08/09 03:01 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Their are Dana 60, Dana 60 HD (a bit beefier/heavier housing) and other even larger/heavier Dana rears (ex: Dana 70) that look similar. The Dana 60 for trucks do not have provision for a pinion-snubber and typically are 30-spline (same as 8 3/4 Mopar) versus the 35-spline side gears of the car-type Dana 60. Green Bearings will come in handy if this is a Car-Conversion. Here are some links: Dana Identification Dana 60 Maintenance Manual Dana 60 Usage List Dana 60 Info Moparts Dana 60 BOM Numbers ID Below is a Top-View of a Dana 60 HD, slightly heavier (some would say unnecessarily heavier, excess weight) but even these can work as good car-rears.
