Dumb Q but does it matter what brand truck Dana 60 #491526
10/08/09 10:31 AM
10/08/09 10:31 AM
The Wet Coast, Canada
megajoltman Offline OP
I will probably end up buying a cheap older truck Dana does matter if its a ford,chevy,mopar.It will be shortened and axles made for it, 410-488 gears with a Detroit Locker
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Dumb Q but does it matter what brand truck Dana 60 [Re: megajoltman] #491527
10/08/09 03:01 PM
10/08/09 03:01 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Their are Dana 60, Dana 60 HD (a bit beefier/heavier housing) and other even larger/heavier Dana rears (ex: Dana 70) that look similar.
The Dana 60 for trucks do not have provision for a pinion-snubber and typically are 30-spline (same as 8 3/4 Mopar) versus the 35-spline side gears of the car-type Dana 60.
Green Bearings will come in handy if this is a Car-Conversion.
Here are some links:
Dana Identification
Dana 60 Maintenance Manual
Dana 60 Usage List
Dana 60 Info
Moparts Dana 60 BOM Numbers ID
Below is a Top-View of a Dana 60 HD, slightly heavier (some would say unnecessarily heavier, excess weight) but even these can work as good car-rears.
Re: Dumb Q but does it matter what brand truck Dana 60 [Re: D_C] #491528
10/08/09 04:59 PM
10/08/09 04:59 PM
seems to be lots of old Ford & Chevy Dana's out there.
Re: Dumb Q but does it matter what brand truck Dana 60 [Re: megajoltman] #491529
10/08/09 07:04 PM
10/08/09 07:04 PM
D_C Offline
D_C  Offline
I see used, perfectly good units sent to the crusher every week at the local Pick-A-Part.
