440 in a J body...Whos done it ??? #490924
10/07/09 07:04 PM
10/07/09 07:04 PM
South Dakota
Mirada440 Offline OP
South Dakota
Just curious....Always thought it would be cool to have a 440 in my mirada or cordoba someday... Would like to hear some input from anyone whos done it...Maybe some pics...I was told before its not to hard to put a BB in them...Any truth to it ???
Re: 440 in a J body...Whos done it ??? [Re: Mirada440] #490925
10/07/09 09:11 PM
10/07/09 09:11 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
was a guy on here had a big block mirada, name was Bubba i think.
Re: 440 in a J body...Whos done it ??? [Re: Mirada440] #490926
10/07/09 09:14 PM
10/07/09 09:14 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I haven't done it, but I looked into it back when I was building mine. It's pretty much a drop in deal with the schumacher conversion mounts. Only things I can think of is the power brake booster is going to be in the way of the valve cover, so you'll have to get a small K car one or go manual. There will be no off the shelf headers that will work, but I remember reading a set of ones for a B body will work if you modify the tube for #7. Also the rear end will probably need to be upgraded if you have the 8.25, and definitely if you have the 7.25.
Re: 440 in a J body...Whos done it ??? [Re: 440newport] #490927
10/07/09 10:22 PM
10/07/09 10:22 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Schumacher has headers that fit the swap. They are spendy and not large tube, but they are better then manifolds.
Re: 440 in a J body...Whos done it ??? [Re: Mirada440] #490928
10/07/09 10:31 PM
10/07/09 10:31 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I've done it. VERY easy IMO.
K car brake booster, rear half of a ClubCab longbox mid-late 70s Dodge truck, 8 3/4 out of a 66 B body with the spring perch holes opened up, late model "spool" mounts, milodon deep pan, I had Hedman hedders with the rear tube on the driver's side modified.
It was more or less a bolt in.
CrAzYMoPaRGuY
Re: 440 in a J body...Whos done it ??? [Re: CrAzYMoPaRGuY] #490929
10/11/09 03:56 PM
10/11/09 03:56 PM
South Dakota
South Dakota
Anyone have any good close up pictures of a B/RB in a J body??? Can you still use the power steering box??? Some good pictures would be great..Would really like to see some of the headers and the radiator support...One guy told me i just need to dent the rear header tube...Is it that simple??
Re: 440 in a J body...Whos done it ??? [Re: Mirada440] #490930
10/11/09 04:01 PM
10/11/09 04:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Is not a big trick job.
Re: 440 in a J body...Whos done it ??? [Re: Mirada440] #490931
10/12/09 06:22 PM
10/12/09 06:22 PM
Canada
Canada
My car was power steering, late model PS brackets just bolt on. I prefer cutting the rear header tube and rerouting it, mine was easy and fit with no problems.
I had the original J body rad opened up to a stunningy big.... (drumroll please) TWO core! lol Bever had any problems with heat whatsoever, and it was a daily driver.
CrAzYMoPaRGuY
Re: 440 in a J body...Whos done it ??? [Re: CrAzYMoPaRGuY] #490932
10/16/09 07:03 PM
10/16/09 07:03 PM
South Dakota
South Dakota
Thanks for the info guys i think i might try the swap over the long winter
