8.75 or 9" Rear?
#490476
10/07/09 09:23 AM
10/07/09 09:23 AM
Posts: 84 NC
Badfish67
NC
My car is all Mopar and I hate the thought of putting a 9" rear in it, but i'm about to back half the Barracuda and everyone is telling me to go with a 9" rear. Can I hear from some of the back halfed guys that run sub 10's please.
1967 Barracuda
360ci/727
9.723ET @139.44mph
Re: 8.75 or 9" Rear?
[Re: Badfish67]
#490478
10/07/09 09:27 AM
10/07/09 09:27 AM
Posts: 10,038 MN
JERICOGTX
MN
No way I would consider a 8 3/4 on a back half car. Hook hard one time, and it will spit the ring gear, pinion gear, and main caps out in one shot. Don't waste your time with one.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#490479
10/07/09 09:35 AM
10/07/09 09:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Jeff
You might be right..lol My first all out pass in a mild 440 and 6psi of boost exploded the ring/pinion and caps into a thousand pieces. To the rears credit it was 30something uears old and had at least 200 runs on it.
[Re: Mr.Yuck]
#490480
10/07/09 09:44 AM
10/07/09 09:44 AM
Posts: 10,038 MN
JERICOGTX
MN
With a 8 3/4 it's not a matter IF it will break, it's a matter of WHEN??? Why risk it. Install a 9" in it right from the start.
Jeff
69 GTX
68 Road Runner
[Re: Mr.Yuck]
#490481
10/07/09 09:45 AM
10/07/09 09:45 AM
Posts: 84 NC
Badfish67
NC
Yea, if I go with a 9" it will be a fabricated housing that my chassis guy builds. I'll be running some big tires and spraying some NOS too.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Badfish67]
#490483
10/07/09 09:52 AM
10/07/09 09:52 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Do not waste your time with the 8 3/4. Get a 9" and be done with it. CHIP
[Re: an8sec70cuda]
#490484
10/07/09 09:56 AM
10/07/09 09:56 AM
Posts: 8,165 Left Coast
BobR
Left Coast
8 3/4 rears are fine for stock eliminator and street guys but, really, most serious racers use some aftermarket version of the Ford 9"-and they do it for a reason.
[Re: Badfish67]
#490485
10/07/09 10:15 AM
10/07/09 10:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Like I always say... weight is the killer... if you believe the car will be light then the 8 3/4 will work fine.... I've been running the 8 3/4 for YEARS... I did break the first one after 600+ passes... BUT my car is LIGHT... but I have had a best 60' of 1.19 with my lowly 8 3/4... now I run the alum center for it... much stronger... the one I broke was completely stock except for the 4.88 gear(the first 2 years it had the stock cone style posi). If you think the car will be heavy... go a different direction... JMO
[Re: 68valiant68]
#490487
10/07/09 11:13 AM
10/07/09 11:13 AM
Posts: 84 NC
Badfish67
NC
The Dana 60 is out because of the weight and changing gears are a pain in the butt. I race 1/8 and 1/4 so changing the 3rd member is no big deal on the 8.75 or 9".
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Bigcube]
#490490
10/07/09 12:17 PM
10/07/09 12:17 PM
BobR
Left Coast
I don't find this a good argument against a D60. Most people don't have the extra coin to have 2 GOOD third members laying around. Seems like a good 9" center will be up around $1500?
Our Dewco was closer to 5000.
