Re: 1964 B body can stock hood clear 528" crate Hemi?
[Re: kz5rt2]
#490193
10/07/09 04:22 PM
10/07/09 04:22 PM
Posts: 2,118 at large
moparphillie
at large
If you use a stock Mopar V/8 K Member and Schumacher Engine Conversion Mounts, you do not have to invert or cut the Passenger side shock tower to get the engine in the car. With this stated combination, you may have to disconnect the top stud on the Passenger side shock to remove the Passenger side valve cover. Also if you use the Schumacher Engine Mounts, you must also use either the 2 1/8" or 2 1/4" TTI Headers. Regarding hood clearance, like Butch just stated, it depends on the intake manifold used. If you want to use the NEW STYLE 1" taller Mopar Performance Cross Ram Intake Part Number p5007534, the 1" aluminum adapter plates ( spacers under the carburetors ) and the Holley 4235 and 4236 carburetors and some type of air cleaners like I did, FORGET IT... At the very minimum, you will have to cut two 10" holes in your stock hood, you will have to remove some of the Center and Passenger side under hood bracing and you will need to install either the Super Stock scoop or some other type of scoop. Ask me how I know this ... I just did this whole project on my 1965 Belvedere I and I am still fighting to find two ( 2 ) 9" x 2" air cleaners that will fit under the Super Stock scoop with the hood closed. You can also use the two ( 2 ) Air Horn / Velocity Stacks in place of the two ( 2 ) small air cleaners if you have an extra $ 400.00 to $ 600.00 burning a hole in your pocket. Bottom Line... there is a lot of work in stuffing a Hemi in a 1964 / 65 "B" Body. Obviously, it can be done, but it is NOT an easy conversion. Good Luck
[Re: AndyF]
#490197
10/12/09 08:50 PM
10/12/09 08:50 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
Hood clearance is probably the least of your worries. How about the work involved to invert the shock tower?
It really isn't all that much work, it is, but in the same aspect its not. Quicksilver on here has done that mod many times.
[Re: prochargedhemi]
#490198
10/12/09 09:47 PM
10/12/09 09:47 PM
Posts: 369 Chicago
curbman68
Chicago
I would love to see pictures of his work.
[Re: moparphillie]
#490199
10/13/09 05:33 AM
10/13/09 05:33 AM
Posts: 1,973 SoCal
jake4cars
SoCal
This is my friend Dennis Chapman's 65, sits on Schumacher mounts and TTI headers,very good overall fit, fairly easy to work on. He could probably gain a little more by trimming unused threads on top of shock. At any rate, no need to invert tower. The crossram definitely doesn't fit under the stock hood,LOL Joey
