not a Mopar but some Mopars models used the same unit
#489996
10/06/09 07:02 PM
10/06/09 07:02 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
My dad have a 1975 116 Mercedes ( 280S ) wich uses a York AC compressor like some 70s Mopars.
I am suspicious the Hoses were conected crossed.
Could a York AC compressor unit get crossed hoses conected AND STILL WORK ?
Re: not a Mopar but some Mopars models used the same unit
[Re: stumpy]
#489998
10/06/09 11:41 PM
10/06/09 11:41 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Ma used a York? When? Ive only seen them in aftermarket applications (or a Tecumseh). As far as factory, I thought it was all RV2 until the Sanden came out
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#489999
10/07/09 12:30 AM
10/07/09 12:30 AM
NachoRT74
Valencia, España
well, locally they did specially after 75... I though in USA too on some models... well, definitelly I can be wrong though physycally is posible cross the lines on these compressors, but it looks is wrong to make it. It looks then on my dads car someday in the past compressor was changed to a diff suction hose side compressor. Checked some hose routings and suction hose goes directly to firewall, same than my car does, but hose doesn't meet with holding locations and brackets on engine bay.
[Re: NachoRT74]
#490000
10/07/09 01:24 AM
10/07/09 01:24 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
No way the ac can work if you switch the hoses.
I'm not sure what the pressures would end up like, but with the restriction(oriface tube, txv, whatever your system has...) in there they would be way out to lunch.
It would try to cmpress the low side, and evac th high side, and you end up with a bunch of nothing.
It would be like putting the carb and fuel system on the exhaust side of the motor, and the muffler on top of the intake.. It just won't run like that.
[Re: dave571]
#490001
10/07/09 06:32 AM
10/07/09 06:32 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I know nothing here...just thinking out loud...
why couldn't it run "backwards"? my house is set up to run the AC in either direction, run it one way, and the hot compressed freon goes outside the house, and the cold expanded freon comes inside the house. this makes the house cold.
flip it around in the winter time...hot compressed freon comes inside the house, cold expanded freon goes outside the house, and heats the house up.
the car system wouldn't work the same way?
**Photobucket sucks**
[Re: Commando1]
#490003
10/07/09 10:12 AM
10/07/09 10:12 AM
NachoRT74
Valencia, España
No, really Venezuelan Mopars after 75 got the york compressor, so dunno why I though on some USA models could it be in that way too.
a friend of mine has a 76 dart with Factory AC and got a York unit.
Personally I have the RV2, but is a 74 Charger
whatever, I was checking some York compressor pics on the web and noticed they were made with Suction outled ( labeled with S or complete word ) on both sides. Simply my Dads car compressor should be changed someday in the past for a "wrong" unit by last owner. That's my conclusion
[Re: 70Cuda383]
#490004
10/07/09 10:41 AM
10/07/09 10:41 AM
dave571
In theory it would be possible, but I think the location of the restricton in the car system would make it not work.
A system designed to work lik,e you home one, likely has a different valve system so it work.
[Re: 70Cuda383]
#490005
10/08/09 11:03 AM
10/08/09 11:03 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
[...why couldn't it run "backwards"? my house is set up to run the AC in either direction, run it one way, and the hot compressed freon goes outside the house, and the cold expanded freon comes inside the house. this makes the house cold.
Your home HVAC system is called a heat pump. All principles of thrmodynamics are the same in boh cases but the plumbing is completely different.
