Another cam choice question
#489646
10/06/09 09:52 AM
10/06/09 09:52 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
I've got a '68 Sweptline. When I got it, it already had a 440 transplanted into it. I ran it for a couple of years (over 2.5) after putting Eddy heads on it (in my carport working over the fenders). Last week I broke the crank behind the #4 main, probably from running too much timing because I never bothered to tame down the mechanical advance in the dizzy.
Long story short, I've had a 440 sitting in a barn completely buttoned up that I bought about a decade ago. I took it apart this weekend and it had recently been rebuilt (though ran) and looks great. I'm going to swap the heads over but was wondering what you all thought might make for a good cam.
Current setup: * Shorty headers ('68 pickup frame means you buy very expensive long headers or make your own) * Eddy heads with 84cc chambers * 750 Holley * stock rockers, aftermarket lighter push rods, stock lifters * stock converter going to a 727 ('68 from a c-body) * Unsure of rear end gearing * I believe pistons are stock replacement (meaning 0.050 in the hole) but will check later today * Eddy performer RPM intake manifold
I know I'm forgetting some stuff but that's what comes off the top of my head.
The pickups supposedly weigh less than a b-body but more than an a-body. I've never weighed mine so I don't know for sure.
The truck is street driven, often goes to work (in terrible Atlanta traffic), is used to run to the lumber yard from time to time, and serves as a weekend cruiser. I'm thinking of one of the following two cams but wonder if they are too aggressive for what I do.
Comp Cams XE275HL-10 or Lunati LUN-60304
Re: Another cam choice question
[Re: Chilort]
#489647
10/06/09 11:05 AM
10/06/09 11:05 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd use the lunati voodoo 60303.
[Re: Chilort]
#489658
10/07/09 10:09 PM
10/07/09 10:09 PM
Posts: 7,506 Az
Crizila
Az
Good move on the complete tear down. You might want to look at having the rods resized ( or at least checked ) and also checked for straightness.
Fastest 300
[Re: 74RR]
#489659
10/07/09 11:59 PM
10/07/09 11:59 PM
DaytonaTurbo
Manitoba, Canada
What kind of lope does the Voodoo 60303 have?
With the header cutouts open it sounds like a mean street/strip machine. With the header cutouts closed it sounds barely any more aggressive than a stock cam by the time the sound makes it out the back of my exhaust tips.
