need help msd fried! #489434
10/05/09 08:41 PM
10/05/09 08:41 PM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
i got 74 cuda with 440 msd 6al with pro billet dist and march proformance serpintine pulley and belts with a "one" wire altenator that has a built in voltage reg from march. if anyone got similar setup do i still need my factory volt regulator? had 6al hooked up correct and something burnt up my reg,blowed fuse at relay, and blowed my 6al also! any suggestions
Re: need help msd fried! [Re: jbcuda] #489435
10/06/09 08:21 AM
10/06/09 08:21 AM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
anybody?
Re: need help msd fried! [Re: jbcuda] #489436
10/06/09 08:55 AM
10/06/09 08:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I don't believe in one wire alternators BUT all the wiring from the old regulator should have been unhooked and taped. It charges one field wire with 12 V on a 2 field system and the only wire on a one field system it likely shorted out??
