Challenger driveshaft length.
#489253
10/05/09 06:42 PM
10/05/09 06:42 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
How long is a 4 speed 8 3/4 driveshaft for a Challenger?? I assume engine and year shouldn't matter but its a 73 with a small block.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Challenger driveshaft length.
[Re: CJK440]
#489254
10/05/09 07:15 PM
10/05/09 07:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#489255
10/05/09 09:24 PM
10/05/09 09:24 PM
CJK440
Ansonia, CT
Interesting,
After measuring by bottoming the slip yoke, withdrawing it 1" and measuring center to center I am needing a 46.375" long shaft. The one that I took out (is damaged) measures 46.625.
Quite a bit different than the chart. My car is a 73, with a 65-67 B body 8 3/4, a magnum 360 crate and an E-body A833. Quite the hodge podge of parts but shouldn't be any different, right?
[Re: CJK440]
#489256
10/05/09 09:30 PM
10/05/09 09:30 PM
Posts: 4,744 Florida
BDW
[Re: BDW]
#489257
10/05/09 09:44 PM
10/05/09 09:44 PM
CJK440
Ansonia, CT
Whoa,
There is some major conflicts on that chart. Perhaps the lengths are true to the P/N's but I see a difference of 3.8" between a 1970 340 4 speed 8 3/4 challenger to a similarly equipt 73 Challenger.
What gives? I guess I will be safest with my own measurement.
[Re: BDW]
#489258
10/05/09 11:20 PM
10/05/09 11:20 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: CJK440]
#489259
10/05/09 11:22 PM
10/05/09 11:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Whoa,
I know the axle ID should say 7 1/4, not 8 1/4 on some applications, where do you see the "73 difference" that you speak of?
[Re: DAYCLONA]
#489262
10/06/09 08:46 AM
10/06/09 08:46 AM
CJK440
Ansonia, CT
Whoa,
P/N 2996146 71-73 challenger 727/833 w/ 8-3/4 49.89" long.
I suppose I should simply go with my measurement of 46.37". Its .585 longer than what the '73 book calls for. If I went with a stock 73 shaft in my car now the slip yoke would be pulled out 1.585" from bottom which I think is a bit too much. Perhaps thats how the factory did it??
Like I said, the car is a hodgepodge of parts. Magnum motor, b-body rear with DrDiff offset hangers. I suppose approx .5" difference between the factory spec and what I have now is pretty darn good considering.
Just out of curiosity, why would a large joint shaft be a different measurement? Because the slip and pinion yokes being different lengths? I was thinking about having a new shaft made with 7290 yokes and use conversion parts for now and upgrade the slip/pinion yokes later. But that doesn't seem like a good idea if the 7290 parts I get later are different dimensions...
[Re: CJK440]
#489263
10/06/09 03:06 PM
10/06/09 03:06 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
Yes they are larger, both in width & depth (looks like 3/16" total).
Are you taking the measurement with the car on the ground? The centerline of rear axle rotation isn't the transmission tailshaft. Modified rear car height (springs, air shocks, shackle length, etc.) will change the dimension. A little here and there adds up.
[Re: 6bblgt]
#489264
10/07/09 09:44 AM
10/07/09 09:44 AM
CJK440
Ansonia, CT
The car on jack stands under the rear housing.
Shaft is being made now. Hopefully it's the cure for my vibration problem.
