What did this RV-2 comp fit in part #1894397 #489139
10/05/09 04:21 PM
10/05/09 04:21 PM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I'm trying to get the correct EPR valve for my remanufactured RV-2 compressor to put on my 73 Charger 400, but I don't know which one to get. In the 73 parts catalog it shows two different numbers depending on different compressor part numbers but none of the compressor numbers match this remanufacutred one? The number cast into this compressor appears to be 1894397. It could be out of an earlier or later model car. I don't know where to look to cross compressor part numbers to applications.
Re: What did this RV-2 comp fit in part #1894397 [Re: wh23g3g] #489140
10/05/09 05:44 PM
10/05/09 05:44 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
get both of them
Re: What did this RV-2 comp fit in part #1894397 [Re: wh23g3g] #489141
10/05/09 09:41 PM
10/05/09 09:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
if you plan to use R134 gas, classicauto air advices remove the EPR valve because 134 gas charge is around 75% of the original charge...
I'm still thinking on
https://board.moparts.org/ubbthreads/show...e=4#Post5524850
