Is a 3.9L V6 a direct bolt-in swap for a 318? #489112
10/05/09 03:44 PM
10/05/09 03:44 PM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
Just wondering if I could bolt a 3.9 V6 into a vehicle that originally had a 318. My understanding is that the 3.9 is a LA engine with 2 cylinders removed. How about the mounts? Will a MT flywheel from a 318 work with the 3.9, or will there be balance issues? Any aftermarket intakes available for a 3.9? Thanks
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: Dennis_K] #489113
10/05/09 04:03 PM
10/05/09 04:03 PM
Delaware
crazy4carz Offline
crazy4carz  Offline
Delaware
If it did fit....Why? You're going the wrong way.
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: crazy4carz] #489114
10/05/09 08:27 PM
10/05/09 08:27 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no aftermarket intakes available any more...used to be a MP 4bbl.
the 3.9 only has magnum style mounts, it doesn't have the LA ears like the 5.2 and 5.9, so you'll have to fabricate your own.
2017 Grand Cherokee Overland
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: patrick] #489115
10/05/09 09:15 PM
10/05/09 09:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Really, the 3.9L had magnum mounts before there was a Magnum? The 3.9's been around since the mid 80's.
Don't be the exception.
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: Supercuda] #489116
10/05/09 09:35 PM
10/05/09 09:35 PM
scratchnfotraction Offline
been around and got ears on 3.9 v-6
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: scratchnfotraction] #489117
10/05/09 10:30 PM
10/05/09 10:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Holy carp, we agree
Guess that means the apocalypse is upon us
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: Supercuda] #489118
10/05/09 11:05 PM
10/05/09 11:05 PM
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: scratchnfotraction] #489119
10/06/09 02:06 AM
10/06/09 02:06 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
FWIW the 3.9 equiped trucks we've had have gotten no better mpg than the 5.2 equiped trucks we've had. So by chance that's the reason for wanting to do this swap I would rethink it.
Re: Is a 3.9L V6 a direct bolt-in swap for a 318? [Re: DaytonaTurbo] #489120
10/06/09 09:12 PM
10/06/09 09:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have long pondered this swap for my 65 Cuda. Essentially, I would mount the V6 so that the front of it was in the same location as the 273, easy to do with the pre Magnum version. This would give me about 4" extra clearance between the back of the engine and the firewall. THis would allow me to move the trans a similar amount forward. This would allow running an A500/A518 style trans and minimise the floor hacking needed.
It would also allow room for turbo plumbing across the back of the engine for a crossover to a single turbo placed where the battery would be. Room in an early A is limited.
