Tranny ID's for Mopar FWD Transmisisons
#489096
10/05/09 03:32 PM
10/05/09 03:32 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I am going to have to deal with at least 2 FWD Mopar transmission rebuilds in the future. I want to grab a junkyard tranny, rebuild it and swap. BUT I am not sure about how to pick the right Junkyard transmission. Rather than ask 500 questions like will a 90 tranny work in an 84, will a 4 cylinder work behind a v-6 etc etc etc. Is there a good website or resource for Identifying FWD Transmissions and hopefully interchangeability between model lines? I only need it for Mopar stuff. If it were rear wheal drive it would be a no brainer. Thanks
Re: Tranny ID's for Mopar FWD Transmisisons
[Re: IMGTX]
#489097
10/05/09 09:00 PM
10/05/09 09:00 PM
Posts: 672 Wichita, KS
tmef
Wichita, KS
There were changes made through the years with pump design and axle shaft size. Then there's lock-up verses non lock-up. The turbos had some different internals too. V-6's and 4 cylinders do not interchange. What are the cars that you are going to be working on? Model and year.
I am assuming they are automatics. If they are manuals I can help you with that too.
[Re: tmef]
#489098
10/06/09 12:21 AM
10/06/09 12:21 AM
IMGTX
Thanks for the help. One is a 1984 Daytona 4 cylinder. It leaks and starting to slip. I want to rebuild a tranny and just do a swap. The other is a 95 Eclipse 4 cylinder that isn't shifting right. The Eclipse I haven't diagnosed yet. It may not be a rebuild issue. I was told it doesn't slip but won't shift. I gotta look at it first hand. The third is a 94 Acclaim. The tranny is toasted. I feel confident about the rebuild but IDing them is the problem. I know RWD transmissions but FWD are not my cup-o-tea.
[Re: IMGTX]
#489100
10/06/09 10:06 AM
10/06/09 10:06 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
It may be a bad sensor. I recall reading something about it on the EEK Forum.
[Re: tmef]
#489101
10/07/09 10:14 AM
10/07/09 10:14 AM
IMGTX
Thanks for the info. No the Daytona isn't Turbo. I can find lots of other 84/85 4 cylinder Mopars. Will any transmission fit or where there differnt types? How can I tell the model # on the transmission to get a rebuild kit/book? As for the ecclipse I am hoping it is just a sensor or relay. I had a relay go bad on my son's 3.0 Shadow and it did the same thing as I was told this one is doing. I can't really get to look at it until this weekend. Again thanks for the help.
[Re: DaytonaTurbo]
#489105
10/07/09 09:24 PM
10/07/09 09:24 PM
since you guys seem to know your trannys what tranny interchanges with my 96 caravan with a 3.3 automatic.no one can seem to tell me.sorry didnt mean to hijack the post but i relly need to get this van on the road.thanks
#489106
10/08/09 06:39 AM
10/08/09 06:39 AM
#489107
10/08/09 06:48 AM
10/08/09 06:48 AM
You need to get the tag number off it. Is it a 3 or 4 speed?
http://info.automotix.net/transmissions/search.html?make=dodge&model=caravan&year=1996
#489108
10/08/09 11:15 AM
10/08/09 11:15 AM
DaytonaTurbo
Manitoba, Canada
Any trans from a late 80's-mid 90's 3.3 or 3.8 will work. The 3.0 was the only V6 to have the 3sp auto available, and the 3.0's bell housing pattern was different. So while a 3.3 and 3.8 will swap transmissions with each other, a 3.0 will not swap with a 3.3/3.8 trans. 3.3/3.8 never had the 3sp available, only the 604 4sp auto o/d.
Go to the junk yard and look for mid 90's minivans with a 3.3, they are not hard to find, though around here they are a little less common than the 3.0 minivans. Lots of the early 90's new yorkers and dynasty's have the 3.3 as well.
[Re: DaytonaTurbo]
#489109
10/08/09 02:09 PM
10/08/09 02:09 PM
that is what i thought but everyone says it is a 96 only.i have messed around with a few of them and to me they all look the same.it is a 4 speed with od.they are wantin anywhere from 1500 to 2500 to rebuild one.heck the van isnt worth that but it was our main car so i really need to do something
[Re: DaytonaTurbo]
#489111
10/08/09 05:20 PM
10/08/09 05:20 PM
wow a 100 bucks they are at least 250 to 650 around here and that is if you can find one i sure wish i lived where you do it really is getting frustrating
