Page 3 of 80 1 2 3 4 5 79 80
Re: ss/ah hemi pic [Re: SSDAcuda] #48885
12/16/07 10:03 PM
12/16/07 10:03 PM
mi
W
warfish Offline
undercover
warfish  Offline
undercover
W
mi
finally got the valve covers done, and new wires for new design front drive distributor. If you notice no spacers are needed to clear the water pump like the other engine pic on here. Just a little appearance if anyone wants it.
Hope to run it tomorrow.
later
cw
hemimilita.com We are racers, not daycare providers.
Re: ss/ah hemi pic [Re: warfish] #48886
12/16/07 10:16 PM
12/16/07 10:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
What size are them carbs and what CFM will they flow ??
Re: ss/ah hemi pic [Re: warfish] #48887
12/16/07 10:21 PM
12/16/07 10:21 PM
New York
ajcjr Offline
fishstick
ajcjr  Offline
fishstick
New York
later
cw
sweet valve covers, did you put a window in there?
Can you do that to any valve cover?
stockers are way cool
Re: ss/ah hemi pic [Re: ajcjr] #48888
12/16/07 10:27 PM
12/16/07 10:27 PM
MS
crc Offline
crc  Offline
MS
Re: ss/ah hemi pic [Re: REHBERGERRACING] #48889
12/16/07 10:28 PM
12/16/07 10:28 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Ya that was one of them . The last time I saw that car was at my grandfather Jim Ronaghan's funeral . My father Albert and Jim campaigned the Old Trapper cars thought the 60's and 70s . We went to California and picked up a cuda earlier this year and have it ready for a cage now. But my job and the other cuda will make for a hectic work schedule. I will post pictures when I start the cage .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: ss/ah hemi pic [Re: warfish] #48890
12/16/07 10:39 PM
12/16/07 10:39 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
Charlie: now you have me confused, after looking at the spark plug wires on the new engine. What is the firing order of it ???
StewartP
Re: ss/ah hemi pic [Re: StewartP] #48891
12/16/07 10:50 PM
12/16/07 10:50 PM
mi
W
warfish Offline
undercover
warfish  Offline
undercover
W
mi
normal 18736542 distribtor goes clockwise now
Re: ss/ah hemi pic [Re: warfish] #48892
12/16/07 10:55 PM
12/16/07 10:55 PM
StewartP Offline
StewartP  Offline
so you have a 4 - 7 swap from the normal firing order ???
thanks
StewartP
Re: ss/ah hemi pic [Re: StewartP] #48893
12/17/07 11:54 AM
12/17/07 11:54 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....Charlie, on your new valve covers, can I ask you what is there main purpose is? I'm sure it is fun to look at while the engine is idling but other than that what are you looking for? I guess if you pop a pushrod or hurt some rocker gear you would know what side it is on but other than that???
Inquiring minds would like to know.
Thanks for everything.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: ss/ah hemi pic [Re: Troy] #48894
12/17/07 12:01 PM
12/17/07 12:01 PM
mi
W
warfish Offline
undercover
warfish  Offline
undercover
W
mi
I started making them when we started oiling through the pushrods to see how that worked. and you can see if your oil is clean. It also fixes some clearance issues with the rockers.
Re: ss/ah hemi pic [Re: StewartP] #48895
12/17/07 12:01 PM
12/17/07 12:01 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
thanks
StewartP
Many engines builders do this for a few reason. One of the reason is so cylinders 5 and 7 are not firing next to each other...trying to keep them from cross firing.
Please correct me if I'm wrong.
Re: ss/ah hemi pic [Re: warfish] #48896
12/17/07 02:21 PM
12/17/07 02:21 PM
wappinger falls new york
Jimi_Vignogna Offline
charlie what is that block of aluminum for you are machining in the lathe?
Re: ss/ah hemi pic [Re: warfish] #48897
12/17/07 03:48 PM
12/17/07 03:48 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Very nice, Good job and Thanks!!
Re: ss/ah hemi pic [Re: warfish] #48898
12/17/07 04:01 PM
12/17/07 04:01 PM
AndyF Offline
AndyF  Offline
Charlie,
I made a production run of brackets for the Jesel stuff that solved the water pump clerance issue. I changed the distributor bracket so it mounted to the motor plate and then lengthened it a bit to clear the new reverse flow Meziere pump. I also added an adjustable TDC pointer to the crank trigger mount. Shoot me a PM and I'll get you a set of parts to look at if you're interested.
Re: ss/ah hemi pic [Re: Jimi_Vignogna] #48899
12/17/07 05:10 PM
12/17/07 05:10 PM
michigan
64ssmax Offline
64ssmax  Offline
michigan
looks like it is the begining of the intake manifold runners
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: ss/ah hemi pic [Re: Jimi_Vignogna] #48900
12/17/07 11:19 PM
12/17/07 11:19 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I think that is a 4 or 5-axis CNC milling machine. It looks like that will save a lot of fitting and welding of all the pieces. Two of those and weld the plenum on and you're almost done.
Floyd Lippencott IV
Re: ss/ah hemi pic [Re: mr_340] #48901
12/18/07 08:34 AM
12/18/07 08:34 AM
mi
W
warfish Offline
undercover
warfish  Offline
undercover
W
mi
thats right, its on a mill.
Re: ss/ah hemi pic [Re: warfish] #48902
12/18/07 11:26 AM
12/18/07 11:26 AM
Indiana
YbNoRmAL Offline
mopar addict
YbNoRmAL  Offline
mopar addict
Indiana
Charlie, thanks for sharing those pics, cool stuff .
Anybody got any pics of the SS/AH that Tony Depillo was driving this year. Was it a stick or auto?
Re: ss/ah hemi pic [Re: YbNoRmAL] #48903
12/18/07 11:58 AM
12/18/07 11:58 AM
OHIO
SSHemi364 Offline
SSHemi364  Offline
OHIO
Here the pic of Tony DePillo SS/AH and the car is a stick..
thank Joe DePillo
Re: ss/ah hemi pic [Re: SSHemi364] #48904
12/18/07 01:12 PM
12/18/07 01:12 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
What trans is he running in the Cuda? My Buddy is building a AH car, and wants to run a stick, but wants to know which ones hold up to 900hp.
Jeff
69 GTX 68 Road Runner
