Post deleted by Defbob
[Re: 68roadrunner]
#488731
10/05/09 10:55 AM
10/05/09 10:55 AM
Re: glide question for big hp
#488732
10/05/09 11:01 AM
10/05/09 11:01 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
How about this idea. Just build it once and be done with it.
#488733
10/05/09 11:02 AM
10/05/09 11:02 AM
Posts: 877 ky
68roadrunner
ky
you failed to mention just how big of a bullet. At 1500 or 2500 there are differences required
oops my bad. we are thinking in the neighborhood of 1200-1300 for the new engine
[Re: Al_Alguire]
#488734
10/05/09 11:05 AM
10/05/09 11:05 AM
Posts: 877 ky
68roadrunner
ky
how outragous do you go to just build it once?
[Re: MegaDart]
#488738
10/05/09 12:41 PM
10/05/09 12:41 PM
[Re: julian2007]
#488741
10/05/09 03:26 PM
10/05/09 03:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
A pump upgrade is not required with a ringless input shaft. In a dragster application, an 8 clutch drum should be fine, but I would go to 1.80 straight cut gear set and the ringless input. Tire shake is as hard on these parts as torque, hence the suggested upgrades. As far as spending money once, I agree with that. I sell a glide with aftermarket case, ringless input, 1.80 straight cut, 10 clutch drum, roller tailhousing, pro/tree brake, billet servos and other top line parts for $3500. We put this same trans in 3000lb cars that make over 2000hp and have no issues. Sure, I could upgrade it to a Vasco gearset, 300M NASA shaft and gerotor pump and take your $5000, but very few cars need that, so I dont sell many of those.
Monte
