Re: Rebuilding your own 727
[Re: TomsCharger70]
#488347
10/04/09 08:01 PM
10/04/09 08:01 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
couple of years ago i decided to start doing my own trans, bought the 727 Munroes book, the ATSG manual, and this video.. http://cgi.ebay.com/ebaymotors/CHRYSLER-...sQ5fAccessoriesthe video walks you thru dissembley, inspection, and re-assmebley...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#488348
10/04/09 08:10 PM
10/04/09 08:10 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
They really arent too tough IMHO...
I cant afford to have a shop rebuild anything of mine, pluss im a tech, so I have been building 727s, 904, 518s, turbo 350s, power glides, and 700r 4s for years. I have been building the mopar trannys since I was 15, and started blowing up parts and pieces, and so far, I really havent had any issues. I built my own stand for them, and just dig in.
Kasey
[Re: TomsCharger70]
#488350
10/04/09 08:37 PM
10/04/09 08:37 PM
Posts: 16,925 NC
440Jim
NC
Years ago I was told, "The TF 727 is the easiest automatic to work on." So I decided to learn and they were right. Carl Monroe's book is good, get a factory manual also.
You will need snap ring pliers, a slide hammer to remove the pump housing from the case, a front clutch compressor (I made my own), a dial-indicator (to do it right), and basic engine mechanics tools. To replace the bushings, you will need the correct sized drivers (remover and installer). To make it easier to reinstall the pump housing into the case, a pair of 5/16-18 studs are helpful. I made mine by cutting the heads off a couple bolts.
[Re: TomsCharger70]
#488351
10/04/09 08:40 PM
10/04/09 08:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
727's are easy
Call John @ CRT. Just let him know what your goals are and he'll get you the right parts. He's one of the best I've ever delt with and wont steer you wrong.
[Re: TomsCharger70]
#488352
10/04/09 08:41 PM
10/04/09 08:41 PM
dartman366
Mt. Vernon, Ohio
The thing Im kinda most nervous about is that I buy the right parts..
Would a rebuild kit like this be ok..
http://www.summitracing.com/parts/HUP-HP1289K/
or
http://www.campbellenterprises.com/autom...rebuild-kit.php
what about the drums...etc....
/Tom
Go to Mancini racing's web site, that's where i buy my kit's,,, and bushing's bearing's, retainer ring's and stuff from A@A tranmission's.
