Longer wheel studs, front drum brakes, anyone replaced #488267
10/04/09 07:13 PM
10/04/09 07:13 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
them and is there any tricks to it? I see the stock studs have been pressed to help hold the drum to the hub, what do I do about that when I put the longer studs in?
Re: Longer wheel studs, front drum brakes, anyone replaced [Re: Blown61] #488268
10/04/09 09:01 PM
10/04/09 09:01 PM
That crimp (swedged)can be a real problem pressing the old studs out, it can ruin the hub by making it bend if you don't use a spacer behind it when removing the old stud. I think you would be smart to try and grind that crimp down some before starting to press them out
Re: Longer wheel studs, front drum brakes, anyone replaced [Re: Cab_Burge] #488269
10/04/09 09:07 PM
10/04/09 09:07 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Yes grind them. I had to replace a few this summer, and it's alot easier if you grind the swedges down first.
codfish
Re: Longer wheel studs, front drum brakes, anyone replaced [Re: codfish] #488270
10/04/09 09:17 PM
10/04/09 09:17 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Ok, a cut off wheel work? and then what holds the drum on? the wheel and lug nut?
Re: Longer wheel studs, front drum brakes, anyone replaced [Re: Blown61] #488271
10/05/09 12:30 AM
10/05/09 12:30 AM
you got it, a lot of cars come with no drum retainers, some come with retainers and Ma Mopar had a better way,swedging, usually on the drivers side with the left hand threads on the studs and nuts my 1963 Belevedere M.W. car had swedging on both front drums from the factroy Be careful on the grinding, don't mess the threads up on the studs if you want to reuse them again some day
Re: Longer wheel studs, front drum brakes, anyone replaced [Re: Cab_Burge] #488272
10/05/09 12:40 AM
10/05/09 12:40 AM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thank you very much.
