Re: Longer wheel studs, front drum brakes, anyone replaced
[Re: Blown61]
#488268
10/04/09 09:01 PM
10/04/09 09:01 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
That crimp (swedged)can be a real problem pressing the old studs out, it can ruin the hub by making it bend if you don't use a spacer behind it when removing the old stud. I think you would be smart to try and grind that crimp down some before starting to press them out
[Re: Blown61]
#488271
10/05/09 12:30 AM
10/05/09 12:30 AM
Cab_Burge
Ok, a cut off wheel work? and then what holds the drum on? the wheel and lug nut?
you got it, a lot of cars come with no drum retainers, some come with retainers and Ma Mopar had a better way,swedging, usually on the drivers side with the left hand threads on the studs and nuts my 1963 Belevedere M.W. car had swedging on both front drums from the factroy Be careful on the grinding, don't mess the threads up on the studs if you want to reuse them again some day
[Re: Cab_Burge]
#488272
10/05/09 12:40 AM
10/05/09 12:40 AM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
