slick tube repair #488202
10/04/09 05:53 PM
10/04/09 05:53 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Has anyone here ever had a racing tube patched? If so is there anything different to do since it is natural rubber? Thanks
Re: slick tube repair [Re: dartphil] #488203
10/04/09 06:25 PM
10/04/09 06:25 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Yes, I've patched them before, and no just used a regular patch, but only ran them one season and replaced them after that cause I didn't trust it. Did you run a rim screw into it ?
Re: slick tube repair [Re: dartphil] #488204
10/04/09 07:21 PM
10/04/09 07:21 PM
madison, ohio
modified1090 Offline
madison, ohio
i actually got a flat at the track july 4, i had the owner of the track working to get my tire fixed. he put a patch on the tube and suggested putting a patch on the inside of the tire where the nail went though
Re: slick tube repair [Re: dartphil] #488205
10/04/09 08:36 PM
10/04/09 08:36 PM
I have had to patch more than one, be careful when drilling the rims for rim screws with the tires and tubes mounted up Mark and drill them before mounting the tires and rims
Re: slick tube repair [Re: Cab_Burge] #488206
10/04/09 08:57 PM
10/04/09 08:57 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
thanks guys. i don't think it was a rim screw, It has been holding air. Noticed it losing air sunday morning at MMW. I haven't taken it off yet to see if i picked up something at the track.
Re: slick tube repair [Re: dartphil] #488207
10/04/09 09:03 PM
10/04/09 09:03 PM
Check the valve stem and core first before dismounting it
