Block notching a Hemi for a roller cam #488126
10/04/09 03:59 PM
10/04/09 03:59 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Earlier this summer I was at a machine shop that was building a Hemi. I noticed the top areas near the head gasket were notched back to make room for the roller cam push rods to clear.
Is this always necessary to do on all Hemi blocks in order to have a roller cam set up? Do 440's need this done too?
What other modifications, requirements (if any) are needed to do to the block in order to do a roller cam on a Hemi?
Thanks in advance.
Re: Block notching a Hemi for a roller cam [Re: Topcat] #488127
10/04/09 04:11 PM
10/04/09 04:11 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
Solid roller or hydraulic roller? The grinding required for the hydraulic roller cam in a hemi isn't for the faint of heart...
Re: Block notching a Hemi for a roller cam [Re: Paul_B] #488128
10/04/09 04:14 PM
10/04/09 04:14 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I and another member are both interested in doing a solid roller cam. Mine a 472, his a 572.
I'm starting to think now it might be pretty expensive to do it. So I would like to know any details if possible.
Re: Block notching a Hemi for a roller cam [Re: Topcat] #488129
10/04/09 04:14 PM
10/04/09 04:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Depends on the amount of lift and the rocker ratio. A lot of lift moves the pushrod closer to the block as the valve approaches its maximium lift. Likewise, a rocker ratio is changed by moving the pushrod (adjusting screw) closer to the rocker shaft - thus moving the pushrod closer to the block.
Re: Block notching a Hemi for a roller cam [Re: Stanton] #488130
10/04/09 04:16 PM
10/04/09 04:16 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Is there a basic rule of thumb that if going over so much lift .___? then notching is required?
Re: Block notching a Hemi for a roller cam [Re: Topcat] #488131
10/06/09 07:36 PM
10/06/09 07:36 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
You will also need to open the holes up in the heads as well. You will also have to do some relieving in the head gaskets or Cometic have gaskets without holes.
If you are using a mega block, depending on the lifters, you may need to relieve the lifter bosses to clear the link bar.
The 440 does not have this problem as the push rods are straight and their are no push rod holes in the block or head.
Re: Block notching a Hemi for a roller cam [Re: Topcat] #488132
10/06/09 08:54 PM
10/06/09 08:54 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
If it was extensive grinding, it was most likely a hydraulic roller. They require a lot of pushrod clearancing. Most street/bracket solid rollers go in with little to no grinding depending on the combination of parts used. Anything with a hemi is expensive.
