Re: Block notching a Hemi for a roller cam
[Re: Paul_B]
#488128
10/04/09 04:14 PM
10/04/09 04:14 PM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
Solid roller or hydraulic roller? The grinding required for the hydraulic roller cam in a hemi isn't for the faint of heart...
I and another member are both interested in doing a solid roller cam. Mine a 472, his a 572.
I'm starting to think now it might be pretty expensive to do it. So I would like to know any details if possible.
[Re: Stanton]
#488130
10/04/09 04:16 PM
10/04/09 04:16 PM
Topcat
Fremont, CA.
Depends on the amount of lift and the rocker ratio. A lot of lift moves the pushrod closer to the block as the valve approaches its maximium lift. Likewise, a rocker ratio is changed by moving the pushrod (adjusting screw) closer to the rocker shaft - thus moving the pushrod closer to the block.
Is there a basic rule of thumb that if going over so much lift .___? then notching is required?
[Re: Topcat]
#488131
10/06/09 07:36 PM
10/06/09 07:36 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
You will also need to open the holes up in the heads as well. You will also have to do some relieving in the head gaskets or Cometic have gaskets without holes.
If you are using a mega block, depending on the lifters, you may need to relieve the lifter bosses to clear the link bar.
The 440 does not have this problem as the push rods are straight and their are no push rod holes in the block or head.
[Re: Topcat]
#488132
10/06/09 08:54 PM
10/06/09 08:54 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
If it was extensive grinding, it was most likely a hydraulic roller. They require a lot of pushrod clearancing. Most street/bracket solid rollers go in with little to no grinding depending on the combination of parts used. Anything with a hemi is expensive.
