MSD 7 AL3 Help #488103
10/04/09 03:51 PM
10/04/09 03:51 PM
Charleston, SC
safaritow Offline OP
Charleston, SC
Im trying to hook up my RAS to my shift Solenoid. I cant get it to work. I need it hot all the time then when I hit 7200 rpm I need it to cut power so it will shift.
Re: MSD 7 AL3 Help [Re: safaritow] #488104
10/04/09 07:43 PM
10/04/09 07:43 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Here is link to the MSD 7 AL3 Instruction manual.
http://www.msdignition.com/instructions/Products/7230.pdf?terms=7230
The RAS provides a ground path so it looks like you need to add a relay that will cut power to the shift solenoid. My shifter is controled by my delay box.
